Tested with the surround test and no luck I will try with locals and send you the diagnostic again
I just sent one with ABC playin from my tuner that should be dolby 5.1 but that was not the beta . I will send one more
Last one is the beta on ABC
Thank you for the diagnostics. I'm uploading a new beta with a fix now.
Thank glad to help out
Great its working on the new beta
Works for me too using the new beta today
The most recent update, 4.4.2, fixed the issue. Thank you.
