The quality issue is fixed in the latest build.
Thank you, thank you.
Let me know if we need to check Experimental Transcoding, otherwise I will start testing again in 10 min.
AWESOME!
Latest 5 min test (only on TVE so far):
On iMac (i-5-7600):
Live - Transcoder intermittently drops to below 1.00, pause as buffer fills, resumes at +1.XX
Recorded - Excellent
On Qnap 251A:
Live - Transcoder intermittent drops...expected behavior as noted re: CPU in: Pixellation & Stuttering - TVE
Recorded - as expected as in above thread.
However, overall Live and Recorded is improved.
FYI: if you want to see log:
Attaching log for iMac only (Qnap testing will be continued for P & E -TVE thread)
2019/08/11 16:16:02 [HLS] Starting transcoder for channel 6039 from 10.0.0.21 (encoder=h264_videotoolbox, resolution=720, deinterlacer=linear, bitrate=3000)
[h264_videotoolbox @ 0x7fd6d6813200] Color range not set for yuv420p. Using MPEG range.
2019/08/11 16:17:28 [DVR] Starting job 1565553600-ch6039 The Treasure of the Sierra Madre (1948) on ch=[6039]
2019/08/11 16:17:28 [DVR] Waiting 3h42m31.777413s until next job 1565568000-ch6085 Batman (1989)
2019/08/11 16:17:28 [TNR] Sharing existing connection to TVE-Comcast_SSO for ch6039 TCM (clients=2, len=0)
2019/08/11 16:17:28 [DVR] Recording for job 1565553600-ch6039 from TVE-Comcast_SSO ch6039 into "Movies/The Treasure of the Sierra Madre (1948) 2019-08-11-1617.mpg" for 1h57m31.777238s
2019/08/11 16:17:28 [IDX] Generating video index for job 1565553600-ch6039
2019/08/11 16:20:03 [HLS] Stopping transcoder session ch6039-dANY-ip10.0.0.21 @ 4m2.253789s
2019/08/11 16:20:51 [DVR] Waiting 3h39m8.873588s until next job 1565568000-ch6085 Batman (1989)
2019/08/11 16:20:55 [MTS] Statistics for "Movies/The Treasure of the Sierra Madre (1948) 2019-08-11-1617.mpg": skipped=0 unhandled_packets=0 discontinuity_detected=0 transport_errors=0 invalid_pts=0 invalid_dts=0 saw_pcr=true saw_pmt=true highest_pts=266.699267
2019/08/11 16:20:55 [TNR] Closed connection to TVE-Comcast_SSO for ch6039 TCM
2019/08/11 16:20:55 [DVR] Job cancelled: 1565553600-ch6039 The Treasure of the Sierra Madre (1948)
2019/08/11 16:20:55 [DVR] Waiting 3h39m4.194489s until next job 1565568000-ch6085 Batman (1989)
2019/08/11 16:20:55 [DVR] Processing file-7723: Movies/The Treasure of the Sierra Madre (1948) 2019-08-11-1617.mpg
2019/08/11 16:20:55 [DVR] Running commercial detection on file 7723 (Movies/The Treasure of the Sierra Madre (1948) 2019-08-11-1617.mpg)
2019/08/11 16:21:10 [DVR] Commercial detection failed with exit status 1
2019/08/11 16:23:45 [HLS] Starting transcoder for file7723-ip10.0.0.21---3000-720-1 at 0s from 10.0.0.21 (encoder=h264_videotoolbox, resolution=720, deinterlacer=linear, bitrate=3000)
[h264 @ 0x7ff0a401bc00] sps_id 0 out of range
Last message repeated 3 times
[h264 @ 0x7ff0a4804e00] co located POCs unavailable
[h264 @ 0x7ff0a4805400] co located POCs unavailable
[h264_videotoolbox @ 0x7ff0a4802c00] Color range not set for yuv420p. Using MPEG range.
[h264 @ 0x7ff0a4804e00] error while decoding MB 21 32, bytestream -7
2019/08/11 16:26:34 [HLS] Stopping transcoder session file7723-ip10.0.0.21---3000-720-1 (view: 2m43s, out: 2m43.935033s, finished: true)
yes, glad the quality issue is fixed.
@DebbieFL The transcoder only runs for me on OTA channels, which are extremely high quality now. At 1080p 8mbps, which is what I usually have web-streaming set for on my gigabit network, TVE channels don't run transcode, only remux. If I drop down the bitrate of the web-streaming, transcoder will run, but I haven't experienced any intermittent pauses. This is on a Synology DS916+. Guess maybe I am suggesting that if you increase the bitrate, the issue will go away for TVE.
We are re-testing the transcoder change which caused some problems last week. It is available in v2019.08.13.0310
We have tested on DS916+ and DS918+ and are fairly confident it works as expected across CPUs now. More testing would be appreciated.
This bug has also been fixed in the latest build.
Is there a program you recommend for measuring CPU usage for transcoding in Windows 10?
I’ve been monitoring my NAS (Linux), I think in Win10 you have similar monitoring methods...but I’m a Win10 neophyte...hopefully other Win 10 users can assist here!
