v2.01 working here
I was about to say I'm not having this issue, but I checked, and it turns out I am (using v2.01). It looks like things were okay this morning...
2025-01-23 09:53:18 [INFO] Updating channel id list
2025-01-23 09:53:19 [INFO] Close the Signin API session
2025-01-23 09:53:19 [INFO] Number of streams available: 173
2025-01-23 09:53:19 [INFO] Retriving EPG Data
2025-01-23 09:53:19 [INFO] EPG API Call
2025-01-23 09:53:22 [INFO] EPG API Call
2025-01-23 09:53:24 [INFO] Channels: Available EPG data: 173
But not so much now (forced a restart to be sure)...
2025-01-23 16:50:15 [INFO] ⇨ http server started on [::]:7777
2025-01-23 16:50:31 [INFO] Updating channel id list
2025-01-23 16:50:31 [INFO] Close the Signin API session
2025-01-23 16:50:31 [INFO] Number of streams available: 0
2025-01-23 16:50:31 [INFO] Retriving EPG Data
2025-01-23 16:50:31 [INFO] Initialize channel_list
2025-01-23 16:50:31 [INFO] Channels: Available EPG data: 0
Open the m3u or xml files and you'll see they are empty, save the base stuff.
Might be a temporary hiccup from Tubi or a change in their API call, will have to wait on @joagomez for the answer.
For me, it seems that it pooped out within the last hour or so. I tried restarting the container, too. Still, nuthin'.
Yep, both the m3u and xml are empty.
Not sure if this is normal for the container log
2025-01-23T17:49:03.956171557Z [INFO] Updating channel id list
2025-01-23T17:49:03.957101007Z [INFO] Update Token via API Call
2025-01-23T17:49:03.957287461Z [INFO] Update token_sessionAt
2025-01-23T17:49:04.701548105Z [INFO] Close the Signin API session
2025-01-23T17:49:04.702800031Z HTTP: 400: {"code":"INVALID_PARAMS","message":"Request params is invalid"}
2025-01-23T17:49:05.210131635Z [INFO] Close the Signin API session
2025-01-23T17:49:05.669226294Z [INFO] Number of streams available: 176
2025-01-23T17:49:05.680355425Z [INFO] Retriving EPG Data
2025-01-23T17:49:05.681198249Z [INFO] EPG API Call
2025-01-23T17:49:09.303884774Z [INFO] EPG API Call
2025-01-23T17:49:10.459290651Z [INFO] Channels: Available EPG data: 176
2025-01-23T17:49:10.782899453Z [INFO] Updating channel id list
2025-01-23T17:49:10.783135661Z [INFO] Update Token via API Call
2025-01-23T17:49:10.783258384Z [INFO] Update token_sessionAt
2025-01-23T17:49:11.018768427Z [INFO] Close the Signin API session
2025-01-23T17:49:11.019302093Z HTTP: 400: {"code":"INVALID_PARAMS","message":"Request params is invalid"}
2025-01-23T17:49:11.504839226Z [INFO] Close the Signin API session
2025-01-23T17:49:11.937896709Z [INFO] Number of streams available: 176
2025-01-23T17:49:11.940306319Z [INFO] Retriving EPG Data
2025-01-23T17:49:11.941087652Z [INFO] EPG API Call
2025-01-23T17:49:15.250792829Z [INFO] EPG API Call
2025-01-23T17:49:16.401198936Z [INFO] Channels: Available EPG data: 176
2025-01-23T17:49:16.553873710Z [INFO] Running EPG
2025-01-23T17:49:20.201964234Z [INFO] Write XML
2025-01-23T17:49:20.998163696Z [INFO] End EPG
Now I'm seeing 0 streams available in the container log
2025-01-23T22:10:13.737093514Z [INFO] Updating channel id list
2025-01-23T22:10:13.750182985Z [INFO] Update Token via API Call
2025-01-23T22:10:13.750404656Z [INFO] Update token_sessionAt
2025-01-23T22:10:14.707535323Z [INFO] Close the Signin API session
2025-01-23T22:10:14.708451566Z HTTP: 400: {"code":"INVALID_PARAMS","message":"Request params is invalid"}
2025-01-23T22:10:14.829407538Z [INFO] Close the Signin API session
2025-01-23T22:10:14.946690740Z [INFO] Number of streams available: 0
2025-01-23T22:10:14.948888772Z [INFO] Retriving EPG Data
2025-01-23T22:10:14.949122081Z [INFO] Initialize channel_list
2025-01-23T22:10:14.949237379Z [INFO] Update Token via API Call
2025-01-23T22:10:14.949344718Z [INFO] Update token_sessionAt
2025-01-23T22:10:15.126371324Z [INFO] Close the Signin API session
2025-01-23T22:10:15.126698473Z HTTP: 400: {"code":"INVALID_PARAMS","message":"Request params is invalid"}
2025-01-23T22:10:15.263893093Z [INFO] Close the Signin API session
2025-01-23T22:10:15.279909702Z [INFO] Number of streams available: 0
2025-01-23T22:10:15.377287101Z [INFO] Channels: Available EPG data: 0
2025-01-23T22:10:31.993689177Z [INFO] Updating channel id list
2025-01-23T22:10:31.994645240Z [INFO] Update Token via API Call
2025-01-23T22:10:31.994880091Z [INFO] Update token_sessionAt
2025-01-23T22:10:32.239553609Z [INFO] Close the Signin API session
2025-01-23T22:10:32.239766209Z HTTP: 400: {"code":"INVALID_PARAMS","message":"Request params is invalid"}
2025-01-23T22:10:32.365716579Z [INFO] Close the Signin API session
2025-01-23T22:10:32.381364592Z [INFO] Number of streams available: 0
2025-01-23T22:10:32.383400365Z [INFO] Retriving EPG Data
2025-01-23T22:10:32.383612058Z [INFO] Initialize channel_list
2025-01-23T22:10:32.383890829Z [INFO] Update Token via API Call
2025-01-23T22:10:32.384014833Z [INFO] Update token_sessionAt
2025-01-23T22:10:32.613693070Z [INFO] Close the Signin API session
2025-01-23T22:10:32.614043948Z HTTP: 400: {"code":"INVALID_PARAMS","message":"Request params is invalid"}
2025-01-23T22:10:32.729091778Z [INFO] Close the Signin API session
2025-01-23T22:10:32.746412157Z [INFO] Number of streams available: 0
2025-01-23T22:10:32.748405635Z [INFO] Channels: Available EPG data: 0
2025-01-23T22:11:48.698039732Z [INFO] Running EPG
2025-01-23T22:11:48.698965127Z [INFO] Retriving EPG Data
2025-01-23T22:11:48.699143242Z [INFO] Initialize channel_list
2025-01-23T22:11:48.699242548Z [INFO] Update Token via API Call
2025-01-23T22:11:48.699348895Z [INFO] Update token_sessionAt
2025-01-23T22:11:48.922028323Z [INFO] Close the Signin API session
2025-01-23T22:11:48.922303643Z HTTP: 400: {"code":"INVALID_PARAMS","message":"Request params is invalid"}
2025-01-23T22:11:49.064950195Z [INFO] Close the Signin API session
2025-01-23T22:11:49.081012622Z [INFO] Number of streams available: 0
2025-01-23T22:11:49.082965774Z [INFO] End Read EPG
2025-01-23T22:11:49.161928841Z [INFO] Write XML
2025-01-23T22:11:49.202191589Z [INFO] End EPG
My guide is also, but check the m3u, xml and container log.
Yeah was doing that as you posted ... no good
2025/01/23 14:45:17.804746 [ERR] Failed to start stream for ch3008: M3U: Could not fetch playlist from 192.168.50.83:7778: GET: http://192.168.50.83:7778/tubi/watch/400000099: 500 INTERNAL SERVER ERROR
2025/01/23 14:45:17.825656 [HLS] Couldn't generate stream playlist for ch3008-dANY-ip192.168.50.186: M3U: Could not fetch playlist from 192.168.50.83:7778: GET: http://192.168.50.83:7778/tubi/watch/400000099: 500 INTERNAL SERVER ERROR
2025/01/23 14:45:17.825953 [HLS] Stopping transcoder session ch3008-dANY-ip192.168.50.186 (out=0s finished=false first_seq=0 last_seq=-1)
Just tried to install from One Click and got the error message
"{"error":"invalid source url: no channels found in m3u"}"
That makes sense. Channels DVR won't accept a source with an empty m3u. When/if we all get the docker container generating the channel list properly again, the "One Click" installation should work.
It appears something has changed in the last couple of hours will need to investigate
Receiving the following in one of their API calls
"alert": "Tubi is experiencing technical issues. You're on a degraded experience now.",
will need to wait for this to clear to see if the APIs have changed or if this is a temporary issue
Was the Super Bowl today?
better issues now than during the SB
Tubi TV: 0 channels (-141)
They are probably moving servers around so they can handle the Super Bowl.
Their website displays this when trying to search
Search is on a break, not broken
Scheduled maintenance ends at 9:20 PM.
or … turning off their API and adding DRM to everything, in preparation for the Super Bowl
Tubi's back up for me now.
+1 working for me
Must have been that scheduled maintenance
