The issue with FBN audio has been resolved in the latest build.
Thanks, You have created a great product!
TV Everywhere Beta has been incredible on both ends live viewing and DVR. But last day or 2 Iām Having issues with CBS Sports HQ and CBSN trying to view on PC live brings up āError: TVE: Stream not Liveā
Also When trying to DVR the same two channels logs show same āStream not Liveā Errors
CBS Sports HQ is working for me.
CBSN has been fixed in the latest build.
Updated to newest build and CBS sports HQ is working fine, But then noticed that CBSN had changed channel number and location and when watching the live stream it is actually the same as The CBS Sports HQ channel not CBS NEWS channel.
Iām assume the turner sharing feature does not work with TVE since it is not using a turner, but was hoping to try to conserve bandwidth.
Tuner sharing works with TVE streams: one copy is downloaded over the internet and shared amongst multiple viewers or recordings.
In fact this works even if you set Tuner Sharing to off, because the TVE streams are generated by the DVR server and thus are always shared.
Oops. This is fixed now in the latest build which will be available in the next 10 minutes.
Updated to latest build if this one is the latest?(2019.07.18.0310)
I am still seeing CBS Sports HQ broadcast on the CBSN (News) Channel for Live and DVR
Looks like I messed up the guide data for CBS Sports vs CBS News. That should be fixed in the next build.
The video feeds look right to me though. The logos are different:
This seems fixed on my end, and thank you for adding CBS Sports Network! CBSN vs. CBSSHQ vs. CBSSN is some very confusing naming on their part.
I am now seeing the fix all is working well. You guys have a amazing service here. Keep up the great work.
Is the Discovery Channel missing for anybody else on Philo? Other properties (TLC, AP, ID) are showing up, just not Discovery proper. Wondering if I just need to re-scan or if there's a known issue.
I see it on Philo and every other streaming service I am testing. It is 6101 - DISCOVERY (DSCHD). You may want to edit and RESCAN that channel. Maybe added after you added Philo.
Not sure if this is a new thing with TVE, but now that I have channels like Discovery on two sources (cable and TVE), DVR pass for a series shows 1 upcoming recording, but clicking on it lists two recordings queued at different times. I noticed this because it failed to record either one this past Monday. (How do I review older logs than what show on the web UI?)
If you're having issues with Discovery please update to the latest version.
View older logs via http://x:8089/log?n=99999
Channels DVR with TVE is a game changer. I absolutely love this product! I have been a Channels user since it was first released on iOS. Great work on this product!
Here is the log for the missed recording.
2019/07/15 18:00:01 [DVR] Starting job 1563238800-6 Fast N' Loud on ch=[6101] 2019/07/15 18:00:01 [TVE] action=auth mvpd=Comcast_SSO requestor=discovery 2019/07/15 18:00:01 [TVE] action=navigate url=https://sp.auth.adobe.com/adobe-services/authenticate/saml?noflash=true&mso_id=Comcast_SSO&requestor_id=discovery&no_iframe=true&domain_name=adobe.com&redirect_url=https%3A%2F%2Fsp.auth.adobe.com%2Fadobe-services%2FcompletePassiveAuthentication 2019/07/15 18:00:01 [TVE] action=request type=Document method=GET url=https://sp.auth.adobe.com/adobe-services/authenticate/saml 2019/07/15 18:00:01 [TVE] action=request type=Document method=GET url=https://oauth.xfinity.com/oauth/authorize 2019/07/15 18:00:02 [TVE] action=request type=Document method=GET url=https://login.xfinity.com/login 2019/07/15 18:00:02 [TVE] action=auth_domain domain=login.xfinity.com 2019/07/15 18:00:02 [TVE] action=request type=Document method=GET url=https://login.xfinity.com/logout 2019/07/15 18:00:02 [TVE] action=request type=Document method=GET url=https://oauth.xfinity.com/oauth/logout 2019/07/15 18:00:03 [TVE] action=request type=Document method=GET url=https://oauth.xfinity.com/oauth/sp-logout 2019/07/15 18:00:03 [TVE] action=request type=Document method=GET url=https://login.xfinity.com/logout 2019/07/15 18:00:03 [TVE] action=request type=Document method=GET url=https://login.xfinity.com/login 2019/07/15 18:00:04 [TVE] action=wait_for_page 2019/07/15 18:00:07 [TVE] action=request type=Document method=GET url=https://oauth.xfinity.com/oauth/authorize 2019/07/15 18:00:07 [TVE] action=request type=Document method=GET url=https://sp.auth.adobe.com/adobe-services/oauth2 2019/07/15 18:00:08 [TVE] action=request type=Document method=GET url=https://sp.auth.adobe.com/adobe-services/completePassiveAuthentication 2019/07/15 18:00:08 [TVE] action=authed 2019/07/15 18:00:08 [TVE] action=wait_for_page done=true reason=auth_finished 2019/07/15 18:00:08 [TVE] action=cookies num_domains=2 num_cookies=23 2019/07/15 18:00:10 [ERR] Failed to start stream on channel 6101 via TVE-Comcast_SSO: TVE: 400 Invalid Request: The request was malformed: v1/streaming/livestream/55c51d636b66d1c17a1ffb9e [Malformed auth header] 2019/07/15 18:00:10 [DVR] Error running job 1563238800-6 Fast N' Loud: could not start stream on channels=[6101]: TVE: 400 Invalid Request: The request was malformed: v1/streaming/livestream/55c51d636b66d1c17a1ffb9e [Malformed auth header] 2019/07/15 18:00:40 [DVR] Starting job 1563238800-6 Fast N' Loud on ch=[6101] 2019/07/15 18:00:40 [ERR] Failed to start stream on channel 6101 via TVE-Comcast_SSO: TVE: 400 Invalid Request: The request was malformed: v1/streaming/livestream/55c51d636b66d1c17a1ffb9e [Malformed auth header] 2019/07/15 18:00:40 [DVR] Error running job 1563238800-6 Fast N' Loud: could not start stream on channels=[6101]: TVE: 400 Invalid Request: The request was malformed: v1/streaming/livestream/55c51d636b66d1c17a1ffb9e [Malformed auth header] 2019/07/15 18:01:11 [DVR] Starting job 1563238800-6 Fast N' Loud on ch=[6101] 2019/07/15 18:01:11 [ERR] Failed to start stream on channel 6101 via TVE-Comcast_SSO: TVE: 400 Invalid Request: The request was malformed: v1/streaming/livestream/55c51d636b66d1c17a1ffb9e [Malformed auth header] 2019/07/15 18:01:11 [DVR] Error running job 1563238800-6 Fast N' Loud: could not start stream on channels=[6101]: TVE: 400 Invalid Request: The request was malformed: v1/streaming/livestream/55c51d636b66d1c17a1ffb9e [Malformed auth header] 2019/07/15 18:01:41 [DVR] Starting job 1563238800-6 Fast N' Loud on ch=[6101] 2019/07/15 18:01:41 [ERR] Failed to start stream on channel 6101 via TVE-Comcast_SSO: TVE: 400 Invalid Request: The request was malformed: v1/streaming/livestream/55c51d636b66d1c17a1ffb9e [Malformed auth header] 2019/07/15 18:01:41 [DVR] Error running job 1563238800-6 Fast N' Loud: could not start stream on channels=[6101]: TVE: 400 Invalid Request: The request was malformed: v1/streaming/livestream/55c51d636b66d1c17a1ffb9e [Malformed auth header] 2019/07/15 18:02:12 [DVR] Starting job 1563238800-6 Fast N' Loud on ch=[6101] 2019/07/15 18:02:12 [ERR] Failed to start stream on channel 6101 via TVE-Comcast_SSO: TVE: 400 Invalid Request: The request was malformed: v1/streaming/livestream/55c51d636b66d1c17a1ffb9e [Malformed auth header] 2019/07/15 18:02:12 [DVR] Error running job 1563238800-6 Fast N' Loud: could not start stream on channels=[6101]: TVE: 400 Invalid Request: The request was malformed: v1/streaming/livestream/55c51d636b66d1c17a1ffb9e [Malformed auth header] 2019/07/15 18:02:43 [DVR] Starting job 1563238800-6 Fast N' Loud on ch=[6101] 2019/07/15 18:02:43 [ERR] Failed to start stream on channel 6101 via TVE-Comcast_SSO: TVE: 400 Invalid Request: The request was malformed: v1/streaming/livestream/55c51d636b66d1c17a1ffb9e [Malformed auth header] 2019/07/15 18:02:43 [DVR] Error running job 1563238800-6 Fast N' Loud: could not start stream on channels=[6101]: TVE: 400 Invalid Request: The request was malformed: v1/streaming/livestream/55c51d636b66d1c17a1ffb9e [Malformed auth header] 2019/07/15 18:03:13 [DVR] Starting job 1563238800-6 Fast N' Loud on ch=[6101] 2019/07/15 18:03:13 [ERR] Failed to start stream on channel 6101 via TVE-Comcast_SSO: TVE: 400 Invalid Request: The request was malformed: v1/streaming/livestream/55c51d636b66d1c17a1ffb9e [Malformed auth header] 2019/07/15 18:03:13 [DVR] Error running job 1563238800-6 Fast N' Loud: could not start stream on channels=[6101]: TVE: 400 Invalid Request: The request was malformed: v1/streaming/livestream/55c51d636b66d1c17a1ffb9e [Malformed auth header] 2019/07/15 18:03:44 [DVR] Starting job 1563238800-6 Fast N' Loud on ch=[6101] 2019/07/15 18:03:44 [ERR] Failed to start stream on channel 6101 via TVE-Comcast_SSO: TVE: 400 Invalid Request: The request was malformed: v1/streaming/livestream/55c51d636b66d1c17a1ffb9e [Malformed auth header] 2019/07/15 18:03:44 [DVR] Error running job 1563238800-6 Fast N' Loud: could not start stream on channels=[6101]: TVE: 400 Invalid Request: The request was malformed: v1/streaming/livestream/55c51d636b66d1c17a1ffb9e [Malformed auth header] 2019/07/15 18:04:14 [DVR] Starting job 1563238800-6 Fast N' Loud on ch=[6101] 2019/07/15 18:04:15 [ERR] Failed to start stream on channel 6101 via TVE-Comcast_SSO: TVE: 400 Invalid Request: The request was malformed: v1/streaming/livestream/55c51d636b66d1c17a1ffb9e [Malformed auth header] 2019/07/15 18:04:15 [DVR] Error running job 1563238800-6 Fast N' Loud: could not start stream on channels=[6101]: TVE: 400 Invalid Request: The request was malformed: v1/streaming/livestream/55c51d636b66d1c17a1ffb9e [Malformed auth header] 2019/07/15 18:04:45 [DVR] Starting job 1563238800-6 Fast N' Loud on ch=[6101] 2019/07/15 18:04:45 [ERR] Failed to start stream on channel 6101 via TVE-Comcast_SSO: TVE: 400 Invalid Request: The request was malformed: v1/streaming/livestream/55c51d636b66d1c17a1ffb9e [Malformed auth header] 2019/07/15 18:04:45 [DVR] Error running job 1563238800-6 Fast N' Loud: could not start stream on channels=[6101]: TVE: 400 Invalid Request: The request was malformed: v1/streaming/livestream/55c51d636b66d1c17a1ffb9e [Malformed auth header] 2019/07/15 18:05:15 [DVR] Starting job 1563238800-6 Fast N' Loud on ch=[6101] 2019/07/15 18:05:16 [ERR] Failed to start stream on channel 6101 via TVE-Comcast_SSO: TVE: 400 Invalid Request: The request was malformed: v1/streaming/livestream/55c51d636b66d1c17a1ffb9e [Malformed auth header] 2019/07/15 18:05:16 [DVR] Error running job 1563238800-6 Fast N' Loud: could not start stream on channels=[6101]: TVE: 400 Invalid Request: The request was malformed: v1/streaming/livestream/55c51d636b66d1c17a1ffb9e [Malformed auth header] 2019/07/15 18:05:46 [DVR] Starting job 1563238800-6 Fast N' Loud on ch=[6101] 2019/07/15 18:05:46 [ERR] Failed to start stream on channel 6101 via TVE-Comcast_SSO: TVE: 400 Invalid Request: The request was malformed: v1/streaming/livestream/55c51d636b66d1c17a1ffb9e [Malformed auth header] 2019/07/15 18:05:46 [DVR] Error running job 1563238800-6 Fast N' Loud: could not start stream on channels=[6101]: TVE: 400 Invalid Request: The request was malformed: v1/streaming/livestream/55c51d636b66d1c17a1ffb9e [Malformed auth header] 2019/07/15 18:06:16 [DVR] Skipping job because program already started 1563238800-6 Fast N' Loud
Just tried a rescan on Discovery Channel, I'm getting an error: "encountered exception 'Uncaught' (5:5)." Current software version is 2019.07.12.2012 (Win7x64). Should I reach out to support?
I am using DirecTV Now as my TVE provider and I notice a number of channels now have this error.
Channels DVR Build: 2019.07.19.1754
Error: TVE: anvato: Missing device/platform parameter.
