U would use the YTTV app in this scenario, to access YTTV.
U would need to use a separate compatible server device to host your Channels DVR server software, if you wish to use YTTV as a TVE source.
If your only option is to use the Shield as sever and client, then you will need to use a different TVE source, there are many supported.
Not sure how much more clear we can be about this to you.
As been pointed out previously, this is the one incompatibility issue with using the Shield as a server.
I suggest u setup Channels back onto a dedicated computer. U dont need anything with that much power, so u can get something pretty cheap.
There is existing threads on this topic and YTTV as a provider. U can use the search feature to find them. The other providers, like Philo, Fubo, etc, most provide the same or similar TVE channel access as YTTV
