TVEverywhere failure
Thank you for your comments. However, the Raspberry Pi 4 w/8GB RAM has low utilization currently when used to stream to one client for testing. Highest number of clients would be two in our household.
HDHomerun, antenna, cabling, support pole, are an expensive solution. I am not interested in the expense at this time.
Thank you for your comment. I may continue to configure and test it. Trouble with frndly tv ad-in currently. I'm communicating in that support page about this trouble.
Thank you for your comments. However, a Synology DS224plus NAS with disk drives is very expensive. I'm not interested in the expense at this time. I will keep this in mind for the future.
HDHomeRun Quatro = ~$100
High-Quality RCA Yagi with mount = ~$35
100ft RG6 coax = ~20
some people pay more than that for their monthly cable bill. But this single expense will get you the major broadcast networks for many years to come with no additional cost or subscriptions required (and at much higher bitrates).
Thank you. I'll be canceling Channels and moving to YouTube TV for a similar channel line up to what I am leaving on Spectrum cable services. Channels DVR, TVEverywhere, the Frndly add-in that did not function, over the air channels that would not connect using TVEverywhere, lack of premium channels, there are reasons I'm leaving Channels.
Best wishes to all that work on these projects.
