Just making sure you have the TZ as America/New_York not just New_York.
Unfortunately schedules direct isn't free, I'll look into ESPN's API.
In the meantime give this a shot
That is a free alternative. I will test the update as well as get back to you.
Couple questions on how to make this work.
I use APITuner. I could import the YTTV Sports Deeplinks into API Tuner as channels. How does the XMLTV and M3U link to APItuner? APItuner pulls the stations based on Gracenote IDs and a guide from that. If I create the lanes in APITuner, how does it direct the content to each lane since there's no Gracenote? I would think that comes from the XMLTV and M3U files, no? It would be great if YTTV Deeplinks could create and M3U and XMLTV setup to already pull from APITuner. I'm lost a bit here.
Another question. I see there's a Celtics game this evening vs. the Rockets at 830PM. I see that in the YTTV app, but I don't see it pulled into YTTV Sports as an event. What might cause it not to show up there?
It is marking everything as live now. It is 8:28 PM on Monday night and it is marking the Jets vs. Raiders, who played on Sunday as live.
This is a problem with YTTV, they are declaring it's live. They are incredibly inconsistent with this so it’s hard to program around a moving target.
What I typically do is add the YTTV Sports channels with a filter on the URL based on the provider used in APITuner. Then I grab the XML from YTTV Sports and use that as the XML for that filtered M3U.
This worked great. Thank you!
If there was a way to add the exact start/end times, that would make this ideal. I think I'll use YTTV Sports Deeplinks to pull in non linear stations such as the ESPN Unlimited stuff that streams on YTTV. Another great tool.
