I recently had a hard drive crash in my Synology NAS so I got a new drive and rebuilt it. I got the DVR up and running and I think it was working ok until I added a second drive and setup a SHR. Now most of my recordings are coming up as 0 minutes. I looked on the NAS and see that there are 2 files for the recordings I’m having issues with.
Example:
One is named normally and is only ~1 mb
Scorpion S04E09 2017-11-20 Its Raining Men of War 2017-11-20-2100
The second is named
Scorpion S04E09 2017-11-20 Its Raining Men of War 2017-11-20-2100_DiskStation_Nov-20-2100-2017_Conflict and is 5.5 gb
If I delete the show from the Recordings the smaller correctly named file is deleted and the conflict file still exists.
I can delete the small file from the File Station app on the NAS and rename the conflict file to the original file name and the video will play full length even though it still says it’s 0 minutes.
Is a SHR configuration supported?
