Hi,
So version 2.1.6 just updated on my ATV and with that update Channels can’t detect my HDHomerun… anyone else have this problem?
I guess 2.1.6 is hot off the press because I can’t see a changelog for it yet.
Cheers
Hi,
Cheers
Can you try “Scan Network” from the Settings tab?
Just gave it a go… displays a spinner for a few seconds but fails to find anything. Checked the HDHomerun and it’s still accessible from other applications, so don’t think it’s got any issues.
Thanks for the quick reply
Try “add tuner manually” and enter the IP address.
If that doesn’t work I would check the network settings on the ATV.
Thanks, manually adding the IP sorted the issue.
Fantastic app by the way!
Cheers
