Hi -
I was hoping for some feedback on my potential setup.
I currently have a Tivo bolt connected to 2 OTA antennas via a mechanical coax switch.
One antenna is roof mounted outside, and the other is attic mounted indoors. They are aimed about 10 degrees differently to pick up the maximum number of stations. Under some conditions one antenna will outperform the other, but it isn’t consistent (rain, wind, snow all seem to impact the signal differently)
I was planning on using 1 Connect to each antenna. My understanding is I can “choose” a channel from within the Channels app depending on which signal is stronger, correct?
Is there any setting or option for the app to auto selecting the strongest signal if there is multiple tuners?
Thanks,
Paul
