Hello out there,
I know i've done this and i'm having trouble replicating the steps... a little insight please?
status
- two PCs different places
- different HD homruns
- Different ISPs.
goal:
to swap DVRs (AWAY FROM HOME sign in)
did it before i know i need to...
- turn off Channels DVR on one computer so that only one is running
- sign in (apple tv / ipad/ iphone etc) using away from home to see those channels/recordings...
now want to swap to other computer - turn one off and other one (channels dvr) on and re-sign in to channels plus using away from home....
issue..
its not seeing the other computer.. (its looking for the one turned off hence if i turn it back on everything works great) but i know i have done this before i'm forgetting a step or something... how do i get it to see the other computer (again with only one dvr running.)? restore command didnt seem to do it.. dont want to uninstall and reinstall... i have stopped the engine (then made sure it wasnt a back ground source to i can use icon and stop as i need to an allow or prevent at start up as i desire)....
this is what i mean how do i refresh where its pointed to????
Remote Access
xxxxxxxx.channelsdvr.net is pointed at 76.216.17.94 but the current IP for this system is 198.52.235.65
thanks in advance.
