I am currently missing the guide on my Channels DVR, when I check in the logs I see this:
2023/10/01 09:34:44.998585 [ERR] Failed to fetch station 24439: invalid response for /stations/24439?api_key=&lineupId=: 403 Forbidden
2023/10/01 09:34:45.070210 [ERR] Failed to fetch station 33579: invalid response for /stations/33579?api_key=&lineupId=: 403 Forbidden
2023/10/01 09:34:45.143187 [ERR] Failed to fetch station 25225: invalid response for /stations/25225?api_key=&lineupId=: 403 Forbidden
2023/10/01 09:34:45.216140 [ERR] Failed to fetch station 33762: invalid response for /stations/33762?api_key=&lineupId=: 403 Forbidden
I tried removing the guide provider and re-adding, and now am unable to add the guide:
2023/10/01 12:53:40.745199 [ERR] Failed to fetch guide providers: invalid response for /lineups?api_key=&country=gbr&postalCode=E11&enhancedCallSign=true: 403 Forbidden
I also tried leaving it a few hours in case I had been rate limited, but am still getting 403 errors.
Is anyone else in the UK seeing the same? I'm not sure if its correct that the API key is blank in the logs?
Thanks
