Having an issue with stuttering playback on Fubo NBC Sports playback for Premier League
What client device are you using connected to the TV? There's a lot of dropped output frames.
Client is AppleTV. Didn’t have this dropped frame problem with the 4K Fox feed yesterday . Only real difference I see immediately is audio is EAC3 and pixel Format.
So not sure if related to audio synchronization???
Yesterday Fox Games worked Flawless for me in 4K
Did you change the video deinterlacer in your settings between the two images?
Top is Hardware and bottom is Blend.
What’s up with the weird scaled resolution 3880x2182? Is that normal/correct?
I did hoping that would resolve but unsuccessful
