Yesterday, I downloaded TestFlight and beta for tvOS. Since then, changing live broadcasts causes freezes for (at best) 20-60 seconds, or system hangs/crashes. Removed TestFlight and beta. Now running the production system but still have same problem. Turning system off and restarting, still broken. Removing and reloading production version seemed to fix it, but after 3 channel changes problem is back. Just a coincidence?
This is really annoying and not wife-friendly as our system is played through a monitor. Stereo HomePod minis; with an Intel 16GB iMac DVR Monterey 12.0.1; 1GB 4 port switch, direct connections. Downloading most recent DVR and restarting everything has not fixed it.
Log now shows many errors:-
2021/11/15 12:43:56.589999 [DVR] Recording engine started in /Volumes/TV_DISK/TV_FILES/ChannelsDVR
2021/11/15 12:43:56.592866 [SYS] Removing old update 2021.08.12.0054
2021/11/15 12:43:56.597610 [DVR] Waiting 1h15m33.402468s until next job 1636955970-77 Jack Irish
2021-11-15 12:43:56.655 channels-dvr[9341:376360] XType: com.apple.fonts is not accessible.
2021-11-15 12:43:56.655 channels-dvr[9341:376360] XType: XTFontStaticRegistry is enabled.
2021/11/15 12:43:57.009343 [SYS] Created database snapshot: backup-20211115.124356
2021/11/15 12:43:57.009545 [SYS] Removing old backup backup-20211030.021019
2021/11/15 12:43:57.350059 [SYS] Bonjour service registered with iMac-Tim.local
2021/11/15 12:44:02.636179 [NAT] Found 2 UPnP routers
2021/11/15 12:44:02.640186 [NAT] Successfully mapped port 8089 using upnp
2021/11/15 12:44:06.618412 [IDX] Pruned 459 expired airings from XMLTV-HDHR in 24.961408ms.
2021/11/15 12:53:36.251972 [DVR] Deleted #1902 /Volumes/TV_DISK/TV_FILES/ChannelsDVR/TV/Aussie Salvage Squad/Aussie Salvage Squad S03E10 2021-11-10-0859.mpg
2021/11/15 12:53:36.406251 [DVR] Deleted #1901 /Volumes/TV_DISK/TV_FILES/ChannelsDVR/TV/Aussie Salvage Squad/Aussie Salvage Squad S03E11 2021-11-09-2223.mpg
2021/11/15 12:53:36.699916 [DVR] Deleted #1502 /Volumes/TV_DISK/TV_FILES/ChannelsDVR/TV/Pointless/Pointless S22E35 2021-08-27-1359.mpg
2021/11/15 13:24:05.596079 [HLS] Couldn't use index for 1784 due to differences in duration. playlistDuration=31148.84632799866 fileDuration=4528.96
2021/11/15 13:24:05.719136 [ENC] Starting encoder for Wheeler Dealers S15E17 1985 Mercedes 300 TD 2021-10-10-1929.mpg in /Volumes/TV_DISK/TV_FILES/ChannelsDVR/Streaming/file1784-ip192.168.1.30-4086000348/encoder-0-1044384417 at 0 (0.000000) (encoder=h264_videotoolbox, resolution=576, deinterlacer=blend, bitrate=8000 segment_size=0.01)
2021/11/15 13:24:05.728177 [HLS] ffmpeg: file1784-ip192.168.1.30: [mp3float @ 0x7f8d60027a00] Header missing
2021/11/15 13:24:05.729139 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7f8d60013200] Dropped corrupted packet (stream = 0)
2021/11/15 13:24:05.729162 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7f8d60013200] Dropped corrupted packet (stream = 1)
2021/11/15 13:24:05.730919 [HLS] ffmpeg: file1784-ip192.168.1.30: [mp2 @ 0x7f8d60016a00] Header missing
2021/11/15 13:24:05.730949 [HLS] ffmpeg: file1784-ip192.168.1.30: Error while decoding stream #0:1: Invalid data found when processing input
2021/11/15 13:24:05.980101 [HLS] ffmpeg: file1784-ip192.168.1.30: [hls @ 0x7f8d60018200] Timestamps are unset in a packet for stream 2. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly
2021/11/15 13:24:06.250635 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7f8d60013200] Dropped corrupted packet (stream = 0)
2021/11/15 13:24:06.252253 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7f8d60013200] Dropped corrupted packet (stream = 1)
2021/11/15 13:24:06.263257 [HLS] ffmpeg: file1784-ip192.168.1.30: [mp2 @ 0x7f8d60016a00] Header missing
2021/11/15 13:24:06.263294 [HLS] ffmpeg: file1784-ip192.168.1.30: Error while decoding stream #0:1: Invalid data found when processing input
2021/11/15 13:24:07.387948 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7f8d60013200] Dropped corrupted packet (stream = 0)
2021/11/15 13:24:07.597675 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] Warning MVs not available
2021/11/15 13:24:07.606539 [HLS] ffmpeg: file1784-ip192.168.1.30: /Volumes/TV_DISK/TV_FILES/ChannelsDVR/TV/Wheeler Dealers/Wheeler Dealers S15E17 1985 Mercedes 300 TD 2021-10-10-1929.mpg: corrupt decoded frame in stream 0
2021/11/15 13:24:14.693119 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] ac-tex damaged at 10 20
2021/11/15 13:24:14.693174 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] Warning MVs not available
2021/11/15 13:24:14.695832 [HLS] ffmpeg: file1784-ip192.168.1.30: /Volumes/TV_DISK/TV_FILES/ChannelsDVR/TV/Wheeler Dealers/Wheeler Dealers S15E17 1985 Mercedes 300 TD 2021-10-10-1929.mpg: corrupt decoded frame in stream 0
2021/11/15 13:24:32.241265 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7f8d60013200] Dropped corrupted packet (stream = 0)
2021/11/15 13:24:37.757814 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] skipped MB in I-frame at 26 22
2021/11/15 13:24:37.759530 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] skipped MB in I-frame at 44 20
2021/11/15 13:24:37.759588 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] Warning MVs not available
2021/11/15 13:24:37.760977 [HLS] ffmpeg: file1784-ip192.168.1.30: /Volumes/TV_DISK/TV_FILES/ChannelsDVR/TV/Wheeler Dealers/Wheeler Dealers S15E17 1985 Mercedes 300 TD 2021-10-10-1929.mpg: corrupt decoded frame in stream 0
2021/11/15 13:24:44.326697 [HLS] ffmpeg: file1784-ip192.168.1.30: /Volumes/TV_DISK/TV_FILES/ChannelsDVR/TV/Wheeler Dealers/Wheeler Dealers S15E17 1985 Mercedes 300 TD 2021-10-10-1929.mpg: corrupt decoded frame in stream 0
2021/11/15 13:24:44.328730 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7f8d60013200] Dropped corrupted packet (stream = 1)
2021/11/15 13:24:53.626723 [HLS] ffmpeg: file1784-ip192.168.1.30: [mp2 @ 0x7f8d60016a00] Header missing
2021/11/15 13:24:53.626760 [HLS] ffmpeg: file1784-ip192.168.1.30: Error while decoding stream #0:1: Invalid data found when processing input
2021/11/15 13:24:54.269701 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7f8d60013200] Dropped corrupted packet (stream = 0)
2021/11/15 13:25:04.210161 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] invalid cbp -1 at 44 32
2021/11/15 13:25:04.215629 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] end mismatch left=1478 1AA4 at 0 36
2021/11/15 13:25:04.215659 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] Warning MVs not available
2021/11/15 13:25:04.215675 [HLS] ffmpeg: file1784-ip192.168.1.30: /Volumes/TV_DISK/TV_FILES/ChannelsDVR/TV/Wheeler Dealers/Wheeler Dealers S15E17 1985 Mercedes 300 TD 2021-10-10-1929.mpg: corrupt decoded frame in stream 0
2021/11/15 13:25:05.210848 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7f8d60013200] Dropped corrupted packet (stream = 0)
2021/11/15 13:25:05.212768 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7f8d60013200] Dropped corrupted packet (stream = 1)
2021/11/15 13:25:05.212928 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] end mismatch left=7362 D891A at 0 36
2021/11/15 13:25:05.212964 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] Warning MVs not available
2021/11/15 13:25:05.213641 [HLS] ffmpeg: file1784-ip192.168.1.30: /Volumes/TV_DISK/TV_FILES/ChannelsDVR/TV/Wheeler Dealers/Wheeler Dealers S15E17 1985 Mercedes 300 TD 2021-10-10-1929.mpg: corrupt decoded frame in stream 0
2021/11/15 13:25:05.214553 [HLS] ffmpeg: file1784-ip192.168.1.30: [mp2 @ 0x7f8d60016a00] Header missing
2021/11/15 13:25:05.214607 [HLS] ffmpeg: file1784-ip192.168.1.30: Error while decoding stream #0:1: Invalid data found when processing input
2021/11/15 13:25:05.474350 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7f8d60013200] Dropped corrupted packet (stream = 1)
2021/11/15 13:25:05.476063 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] skipped MB in I-frame at 26 11
2021/11/15 13:25:05.476100 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] ac-tex damaged at 29 12
2021/11/15 13:25:05.476287 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] Warning MVs not available
2021/11/15 13:25:05.480281 [HLS] ffmpeg: file1784-ip192.168.1.30: [mp2 @ 0x7f8d60016a00] Header missing
2021/11/15 13:25:05.480324 [HLS] ffmpeg: file1784-ip192.168.1.30: Error while decoding stream #0:1: Invalid data found when processing input
2021/11/15 13:25:05.493188 [HLS] ffmpeg: file1784-ip192.168.1.30: /Volumes/TV_DISK/TV_FILES/ChannelsDVR/TV/Wheeler Dealers/Wheeler Dealers S15E17 1985 Mercedes 300 TD 2021-10-10-1929.mpg: corrupt decoded frame in stream 0
2021/11/15 13:25:06.178516 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] skipped MB in I-frame at 14 17
2021/11/15 13:25:06.178554 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] ac-tex damaged at 24 18
2021/11/15 13:25:06.178761 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] Warning MVs not available
2021/11/15 13:25:06.181764 [HLS] ffmpeg: file1784-ip192.168.1.30: /Volumes/TV_DISK/TV_FILES/ChannelsDVR/TV/Wheeler Dealers/Wheeler Dealers S15E17 1985 Mercedes 300 TD 2021-10-10-1929.mpg: corrupt decoded frame in stream 0
2021/11/15 13:25:11.984156 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7f8d60013200] Dropped corrupted packet (stream = 0)
2021/11/15 13:25:11.989655 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7f8d60013200] Dropped corrupted packet (stream = 1)
2021/11/15 13:25:11.989694 [HLS] ffmpeg: file1784-ip192.168.1.30: [mp2 @ 0x7f8d60016a00] Header missing
2021/11/15 13:25:11.989714 [HLS] ffmpeg: file1784-ip192.168.1.30: Error while decoding stream #0:1: Invalid data found when processing input
2021/11/15 13:25:14.200891 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] ac-tex damaged at 19 25
2021/11/15 13:25:14.200961 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] ac-tex damaged at 13 26
2021/11/15 13:25:14.201120 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] Warning MVs not available
2021/11/15 13:25:14.203824 [HLS] ffmpeg: file1784-ip192.168.1.30: /Volumes/TV_DISK/TV_FILES/ChannelsDVR/TV/Wheeler Dealers/Wheeler Dealers S15E17 1985 Mercedes 300 TD 2021-10-10-1929.mpg: corrupt decoded frame in stream 0
2021/11/15 13:25:14.207519 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7f8d60013200] Dropped corrupted packet (stream = 1)
2021/11/15 13:25:14.207997 [HLS] ffmpeg: file1784-ip192.168.1.30: [mp2 @ 0x7f8d60016a00] Header missing
2021/11/15 13:25:14.208014 [HLS] ffmpeg: file1784-ip192.168.1.30: Error while decoding stream #0:1: Invalid data found when processing input
2021/11/15 13:25:16.109554 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7f8d60013200] Dropped corrupted packet (stream = 0)
2021/11/15 13:25:16.109935 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] end mismatch left=18114 D4BDE at 0 36
2021/11/15 13:25:16.109965 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] Warning MVs not available
2021/11/15 13:25:16.111619 [HLS] ffmpeg: file1784-ip192.168.1.30: /Volumes/TV_DISK/TV_FILES/ChannelsDVR/TV/Wheeler Dealers/Wheeler Dealers S15E17 1985 Mercedes 300 TD 2021-10-10-1929.mpg: corrupt decoded frame in stream 0
2021/11/15 13:25:16.123260 [HLS] ffmpeg: file1784-ip192.168.1.30: [mp2 @ 0x7f8d60016a00] Header missing
2021/11/15 13:25:16.123299 [HLS] ffmpeg: file1784-ip192.168.1.30: Error while decoding stream #0:1: Invalid data found when processing input
2021/11/15 13:25:17.795737 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7f8d60013200] Dropped corrupted packet (stream = 1)
2021/11/15 13:25:17.801126 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7f8d60013200] Dropped corrupted packet (stream = 0)
2021/11/15 13:25:17.806795 [HLS] ffmpeg: file1784-ip192.168.1.30: [mp2 @ 0x7f8d60016a00] Header missing
2021/11/15 13:25:17.806832 [HLS] ffmpeg: file1784-ip192.168.1.30: Error while decoding stream #0:1: Invalid data found when processing input
2021/11/15 13:26:06.110797 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] skipped MB in I-frame at 37 4
2021/11/15 13:26:06.111125 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] ac-tex damaged at 7 5
2021/11/15 13:26:06.111144 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] Warning MVs not available
2021/11/15 13:26:06.118625 [HLS] ffmpeg: file1784-ip192.168.1.30: /Volumes/TV_DISK/TV_FILES/ChannelsDVR/TV/Wheeler Dealers/Wheeler Dealers S15E17 1985 Mercedes 300 TD 2021-10-10-1929.mpg: corrupt decoded frame in stream 0
2021/11/15 13:26:07.295654 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7f8d60013200] Dropped corrupted packet (stream = 0)
2021/11/15 13:26:07.295725 [HLS] ffmpeg: file1784-ip192.168.1.30: Last message repeated 1 times
2021/11/15 13:26:07.295756 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7f8d60013200] Dropped corrupted packet (stream = 1)
2021/11/15 13:26:07.302366 [HLS] ffmpeg: file1784-ip192.168.1.30: [mp2 @ 0x7f8d60016a00] Header missing
2021/11/15 13:26:07.302403 [HLS] ffmpeg: file1784-ip192.168.1.30: Error while decoding stream #0:1: Invalid data found when processing input
2021/11/15 13:26:26.894472 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] ac-tex damaged at 35 27
2021/11/15 13:26:26.899984 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] Warning MVs not available
2021/11/15 13:26:26.900028 [HLS] ffmpeg: file1784-ip192.168.1.30: /Volumes/TV_DISK/TV_FILES/ChannelsDVR/TV/Wheeler Dealers/Wheeler Dealers S15E17 1985 Mercedes 300 TD 2021-10-10-1929.mpg: corrupt decoded frame in stream 0
2021/11/15 13:26:27.498754 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] slice mismatch
2021/11/15 13:26:27.498795 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] ac-tex damaged at 31 21
2021/11/15 13:26:27.498809 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] end mismatch left=2950 AB57 at 0 36
2021/11/15 13:26:27.498820 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] Warning MVs not available
2021/11/15 13:26:27.499400 [HLS] ffmpeg: file1784-ip192.168.1.30: /Volumes/TV_DISK/TV_FILES/ChannelsDVR/TV/Wheeler Dealers/Wheeler Dealers S15E17 1985 Mercedes 300 TD 2021-10-10-1929.mpg: corrupt decoded frame in stream 0
2021/11/15 13:26:32.706422 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7f8d60013200] Dropped corrupted packet (stream = 0)
2021/11/15 13:26:38.767703 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] ac-tex damaged at 19 11
2021/11/15 13:26:38.773138 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] skipped MB in I-frame at 1 12
2021/11/15 13:26:38.773189 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] Warning MVs not available
2021/11/15 13:26:38.773205 [HLS] ffmpeg: file1784-ip192.168.1.30: /Volumes/TV_DISK/TV_FILES/ChannelsDVR/TV/Wheeler Dealers/Wheeler Dealers S15E17 1985 Mercedes 300 TD 2021-10-10-1929.mpg: corrupt decoded frame in stream 0
2021/11/15 13:26:43.478790 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] ac-tex damaged at 9 23
2021/11/15 13:26:43.479038 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpeg2video @ 0x7f8d60013800] Warning MVs not available
2021/11/15 13:27:25.010681 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7f8d60013200] Dropped corrupted packet (stream = 0)
2021/11/15 13:27:25.014638 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7f8d60013200] Dropped corrupted packet (stream = 1)
2021/11/15 13:27:25.025229 [HLS] ffmpeg: file1784-ip192.168.1.30: [mp2 @ 0x7f8d60016a00] Header missing
2021/11/15 13:27:25.025265 [HLS] ffmpeg: file1784-ip192.168.1.30: Error while decoding stream #0:1: Invalid data found when processing input
2021/11/15 13:27:29.029158 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7f8d60013200] Dropped corrupted packet (stream = 0)
2021/11/15 13:27:29.029209 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7f8d60013200] Dropped corrupted packet (stream = 1)
2021/11/15 13:27:29.147854 [ENC] Encoder stopped for Wheeler Dealers S15E17 1985 Mercedes 300 TD 2021-10-10-1929.mpg in /Volumes/TV_DISK/TV_FILES/ChannelsDVR/Streaming/file1784-ip192.168.1.30-4086000348/encoder-0-1044384417 after encoding 0 to 4527
2021/11/15 13:29:37.353340 [ENC] Next segment to pre-encode of 4528 is 9m58s from the last request of 3930
2021/11/15 13:29:37.357496 [ENC] Starting encoder for Wheeler Dealers S15E17 1985 Mercedes 300 TD 2021-10-10-1929.mpg in /Volumes/TV_DISK/TV_FILES/ChannelsDVR/Streaming/file1784-ip192.168.1.30-4086000348/encoder-4528-2717949624 at 4528 (4527.000000) (encoder=h264_videotoolbox, resolution=576, deinterlacer=blend, bitrate=8000 segment_size=0.01)
2021/11/15 13:29:37.371499 [HLS] ffmpeg: file1784-ip192.168.1.30: [mp3float @ 0x7ff4aa827400] Header missing
2021/11/15 13:29:37.372280 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7ff4aa808200] Dropped corrupted packet (stream = 0)
2021/11/15 13:29:37.372295 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7ff4aa808200] Dropped corrupted packet (stream = 1)
2021/11/15 13:29:37.372785 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7ff4aa808200] Dropped corrupted packet (stream = 0)
2021/11/15 13:29:37.373357 [HLS] ffmpeg: file1784-ip192.168.1.30: Last message repeated 2 times
2021/11/15 13:29:37.373381 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7ff4aa808200] Dropped corrupted packet (stream = 1)
2021/11/15 13:29:37.610500 [HLS] ffmpeg: file1784-ip192.168.1.30: [mp2 @ 0x7ff4aa818600] Header missing
2021/11/15 13:29:37.610531 [HLS] ffmpeg: file1784-ip192.168.1.30: Error while decoding stream #0:1: Invalid data found when processing input
2021/11/15 13:29:37.689900 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7ff4aa808200] Dropped corrupted packet (stream = 0)
2021/11/15 13:29:37.689948 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7ff4aa808200] Dropped corrupted packet (stream = 1)
2021/11/15 13:29:37.752109 [ENC] Encoder stopped for Wheeler Dealers S15E17 1985 Mercedes 300 TD 2021-10-10-1929.mpg in /Volumes/TV_DISK/TV_FILES/ChannelsDVR/Streaming/file1784-ip192.168.1.30-4086000348/encoder-4528-2717949624 after starting from 4528 without encoding any segments
2021/11/15 13:29:37.756551 [ENC] Next segment to pre-encode of 4528 is 9m54s from the last request of 3934
2021/11/15 13:29:37.760048 [ENC] Starting encoder for Wheeler Dealers S15E17 1985 Mercedes 300 TD 2021-10-10-1929.mpg in /Volumes/TV_DISK/TV_FILES/ChannelsDVR/Streaming/file1784-ip192.168.1.30-4086000348/encoder-4528-2128225816 at 4528 (4527.000000) (encoder=h264_videotoolbox, resolution=576, deinterlacer=blend, bitrate=8000 segment_size=0.01)
2021/11/15 13:29:37.768438 [HLS] ffmpeg: file1784-ip192.168.1.30: [mp3float @ 0x7fe722827c00] Header missing
2021/11/15 13:29:37.769023 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7fe72280b200] Dropped corrupted packet (stream = 0)
2021/11/15 13:29:37.769045 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7fe72280b200] Dropped corrupted packet (stream = 1)
2021/11/15 13:29:37.769487 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7fe72280b200] Dropped corrupted packet (stream = 0)
2021/11/15 13:29:37.770011 [HLS] ffmpeg: file1784-ip192.168.1.30: Last message repeated 2 times
2021/11/15 13:29:37.770030 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7fe72280b200] Dropped corrupted packet (stream = 1)
2021/11/15 13:29:37.951053 [HLS] ffmpeg: file1784-ip192.168.1.30: [mp2 @ 0x7fe72281a200] Header missing
2021/11/15 13:29:37.951085 [HLS] ffmpeg: file1784-ip192.168.1.30: Error while decoding stream #0:1: Invalid data found when processing input
2021/11/15 13:29:38.027654 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7fe72280b200] Dropped corrupted packet (stream = 0)
2021/11/15 13:29:38.027774 [HLS] ffmpeg: file1784-ip192.168.1.30: [mpegts @ 0x7fe72280b200] Dropped corrupted packet (stream = 1)
2021/11/15 13:29:38.148014 [ENC] Encoder stopped for Wheeler Dealers S15E17 1985 Mercedes 300 TD 2021-10-10-1929.mpg in /Volumes/TV_DISK/TV_FILES/ChannelsDVR/Streaming/file1784-ip192.168.1.30-4086000348/encoder-4528-2128225816 after starting from 4528 without encoding any segments. Marked segment as failed.
2021/11/15 13:44:02.619839 [NAT] Successfully mapped port 8089 using upnp
2021/11/15 13:59:30.017047 [DVR] Starting job 1636955970-77 Jack Irish on ch=[25 21 20 2]
2021/11/15 13:59:30.625427 [TNR] Opened connection to 1252EA18/0 for ch20 ABCTV HD
2021/11/15 13:59:30.625495 [DVR] Starting job 1636955970-88 Pointless on ch=[91 90 9]
2021/11/15 13:59:30.625525 [DVR] Waiting 5h31m59.374479s until next job 1636975890-65 Doctor Who
2021/11/15 13:59:30.958270 [DVR] Recording for job 1636955970-77 from 1252EA18 ch20 into "TV/Jack Irish/Jack Irish S02E06 2021-11-15-1359.mpg" for 1h15m29.980432s
2021/11/15 13:59:31.156884 [IDX] Generating video index for job 1636955970-77
2021/11/15 13:59:31.201652 [TNR] Opened connection to 1252EA18/1 for ch90 9HD Perth
2021/11/15 13:59:31.209685 [DVR] Recording for job 1636955970-88 from 1252EA18 ch90 into "TV/Pointless/Pointless S23E36 2021-11-15-1359.mpg" for 1h15m29.374439s
2021/11/15 13:59:31.328545 [IDX] Generating video index for job 1636955970-88
2021/11/15 14:17:55.689723 [HLS] Couldn't use index for 1890 due to differences in duration. playlistDuration=45038.70156200006 fileDuration=4529.12
2021/11/15 14:17:55.851058 [ENC] Starting encoder for Wheeler Dealers S15E18 Shop Talk 2021-11-07-1929.mpg in /Volumes/TV_DISK/TV_FILES/ChannelsDVR/Streaming/file1890-ip192.168.1.30-871856937/encoder-0-2909718209 at 0 (0.000000) (encoder=h264_videotoolbox, resolution=576, deinterlacer=blend, bitrate=8000 segment_size=0.01)
2021/11/15 14:17:55.859895 [HLS] ffmpeg: file1890-ip192.168.1.30: [mp3float @ 0x7fd32801c400] Header missing
2021/11/15 14:17:55.861076 [HLS] ffmpeg: file1890-ip192.168.1.30: [mpegts @ 0x7fd32780b200] Dropped corrupted packet (stream = 0)
2021/11/15 14:17:55.861106 [HLS] ffmpeg: file1890-ip192.168.1.30: [mpegts @ 0x7fd32780b200] Dropped corrupted packet (stream = 1)
2021/11/15 14:17:55.862728 [HLS] ffmpeg: file1890-ip192.168.1.30: [mp2 @ 0x7fd32800b400] Header missing
2021/11/15 14:17:55.862762 [HLS] ffmpeg: file1890-ip192.168.1.30: Error while decoding stream #0:1: Invalid data found when processing input
2021/11/15 14:17:56.146740 [HLS] ffmpeg: file1890-ip192.168.1.30: [hls @ 0x7fd32800cc00] Timestamps are unset in a packet for stream 2. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly
2021/11/15 14:18:35.419181 [ENC] Stopped encoder for Wheeler Dealers S15E18 Shop Talk 2021-11-07-1929.mpg in /Volumes/TV_DISK/TV_FILES/ChannelsDVR/Streaming/file1890-ip192.168.1.30-871856937/encoder-0-2909718209 after encoding 0 to 857
2021/11/15 14:44:02.770469 [NAT] Successfully mapped port 8089 using upnp
2021/11/15 15:15:00.262186 [TNR] Closed connection to 1252EA18/0 for ch20 ABCTV HD
2021/11/15 15:15:00.262186 [TNR] Closed connection to 1252EA18/1 for ch90 9HD Perth
2021/11/15 15:15:00.300565 [SNR] Statistics for "TV/Jack Irish/Jack Irish S02E06 2021-11-15-1359.mpg": ss=100% snq=99%,0%-100% seq=99%,0%-100% bps=3000680,658752-4453344 pps=264,58-383
2021/11/15 15:15:00.312451 [SNR] Statistics for "TV/Pointless/Pointless S23E36 2021-11-15-1359.mpg": ss=100% snq=99%,0%-100% seq=99%,0%-100% bps=4375529,1876992-8640480 pps=377,172-740
2021/11/15 15:15:00.315819 [DVR] Finished job 1636955970-77 Jack Irish
2021/11/15 15:15:00.362342 [DVR] Finished job 1636955970-88 Pointless
2021/11/15 15:15:00.481106 [DVR] Processing file-1918: TV/Pointless/Pointless S23E36 2021-11-15-1359.mpg
2021/11/15 15:15:00.492505 [DVR] Waiting 4h16m29.5075s until next job 1636975890-65 Doctor Who
2021/11/15 15:15:00.502436 [DVR] Waiting 4h16m29.497568s until next job 1636975890-65 Doctor Who
2021/11/15 15:15:01.015248 [DVR] Processing file-1917: TV/Jack Irish/Jack Irish S02E06 2021-11-15-1359.mpg
2021/11/15 15:15:01.137402 [DVR] Running commercial detection on file 1918 (TV/Pointless/Pointless S23E36 2021-11-15-1359.mpg)
2021/11/15 15:24:41.313758 [DVR] Commercial detection for Pointless S23E36 2021-11-15-1359.mpg finished with 6 markers in 9m40.280977637s.
2021/11/15 15:24:41.768051 [DVR] Running commercial detection on file 1917 (TV/Jack Irish/Jack Irish S02E06 2021-11-15-1359.mpg)
2021/11/15 15:33:54.467077 [DVR] Commercial detection for Jack Irish S02E06 2021-11-15-1359.mpg finished with 6 markers in 9m12.791506948s.
2021/11/15 15:44:02.891807 [NAT] Successfully mapped port 8089 using upnp
2021/11/15 16:44:03.059286 [NAT] Successfully mapped port 8089 using upnp
2021/11/15 17:00:02.224195 [TNR] Opened connection to 1252EA18/0 for ch3 SBS ONE
2021/11/15 17:00:02.228302 [HLS] Starting transcoder for channel 3 from 192.168.1.30 (encoder=remux, resolution=, deinterlacer=, bitrate=0)
2021/11/15 17:00:02.756601 [HLS] Probed live stream in 527.850122ms: mpeg2video 720x576 tt 2252881bps
2021/11/15 17:00:04.228333 [HLS] Session ch3-dANY-ip192.168.1.30 started in 2.523171015s
2021/11/15 17:00:04.231971 [ENC] Starting encoder for ch3 in /Volumes/TV_DISK/TV_FILES/ChannelsDVR/Streaming/ch3-dANY-ip192.168.1.30-2971496102/encoder-1-125555690 at 1 (0.936000) (encoder=h264_videotoolbox, resolution=576, deinterlacer=blend, bitrate=8000 segment_size=0.01)
2021/11/15 17:00:09.878078 [HLS] Stopping transcoder session ch3-dANY-ip192.168.1.30 (out: 8.016011s, finished: false)
2021/11/15 17:00:09.923000 [ENC] Stopped encoder for ch3 in /Volumes/TV_DISK/TV_FILES/ChannelsDVR/Streaming/ch3-dANY-ip192.168.1.30-2971496102/encoder-1-125555690 after encoding 1 to 4
2021/11/15 17:00:09.923176 [HLS] ffmpeg: ch3-dANY-ip192.168.1.30-remux: [mpegts @ 0x7fbabf810200] Dropped corrupted packet (stream = 0)
2021/11/15 17:00:09.923210 [HLS] ffmpeg: ch3-dANY-ip192.168.1.30-remux: [mpegts @ 0x7fbabf810200] Dropped corrupted packet (stream = 1)
2021/11/15 17:00:09.928292 [TNR] Closed connection to 1252EA18/0 for ch3 SBS ONE
2021/11/15 17:00:09.928346 [SNR] Statistics for ch3 SBS ONE: ss=100% snq=100% seq=100% bps=3345648,1830368-4427776 pps=290,161-381
2021/11/15 17:00:13.471779 [TNR] Opened connection to 1252EA18/0 for ch3 SBS ONE
2021/11/15 17:00:13.476139 [HLS] Starting transcoder for channel 3 from 192.168.1.30 (encoder=remux, resolution=, deinterlacer=, bitrate=0)
2021/11/15 17:00:14.538580 [HLS] Probed live stream in 1.061671744s: mpeg2video 720x576 tt 2074140bps
2021/11/15 17:00:15.870049 [HLS] Session ch3-dANY-ip192.168.1.30 started in 3.039766523s
2021/11/15 17:00:15.873962 [ENC] Starting encoder for ch3 in /Volumes/TV_DISK/TV_FILES/ChannelsDVR/Streaming/ch3-dANY-ip192.168.1.30-2912491589/encoder-1-2541300816 at 1 (1.568000) (encoder=h264_videotoolbox, resolution=576, deinterlacer=blend, bitrate=8000 segment_size=0.01)
2021/11/15 17:21:56.542552 [HLS] ffmpeg: ch3-dANY-ip192.168.1.30-remux: [mpegts @ 0x7fc51e808200] Dropped corrupted packet (stream = 2)
2021/11/15 17:44:03.238155 [NAT] Successfully mapped port 8089 using upnp
2021/11/15 18:18:54.399629 [ENC] Transcoder has handled 5000 segments and will be restarted
2021/11/15 18:18:55.058612 [ENC] Stopped encoder for ch3 in /Volumes/TV_DISK/TV_FILES/ChannelsDVR/Streaming/ch3-dANY-ip192.168.1.30-2912491589/encoder-1-2541300816 after encoding 1 to 4718
2021/11/15 18:18:55.070258 [ENC] Starting encoder for ch3 in /Volumes/TV_DISK/TV_FILES/ChannelsDVR/Streaming/ch3-dANY-ip192.168.1.30-2912491589/encoder-4719-1998021651 at 4719 (4717.848000) (encoder=h264_videotoolbox, resolution=576, deinterlacer=blend, bitrate=8000 segment_size=0.01)
2021/11/15 18:31:44.205869 [HLS] Stopping transcoder session ch3-dANY-ip192.168.1.30 (out: 1h31m31.208011s, finished: false)
2021/11/15 18:31:44.215533 [ENC] Stopped encoder for ch3 in /Volumes/TV_DISK/TV_FILES/ChannelsDVR/Streaming/ch3-dANY-ip192.168.1.30-2912491589/encoder-4719-1998021651 after encoding 4719 to 5487
2021/11/15 18:31:44.215698 [HLS] ffmpeg: ch3-dANY-ip192.168.1.30-remux: [mpegts @ 0x7fc51e808200] Dropped corrupted packet (stream = 0)
2021/11/15 18:31:44.215718 [HLS] ffmpeg: ch3-dANY-ip192.168.1.30-remux: [mpegts @ 0x7fc51e808200] Dropped corrupted packet (stream = 1)
2021/11/15 18:31:44.220412 [TNR] Closed connection to 1252EA18/0 for ch3 SBS ONE
2021/11/15 18:31:44.224320 [SNR] Statistics for ch3 SBS ONE: ss=100% snq=100% seq=100% bps=2402710,738464-5477568 pps=216,67-469
2021/11/15 18:31:49.217002 [TNR] Opened connection to 1252EA18/0 for ch3 SBS ONE
2021/11/15 18:31:49.220632 [HLS] Starting transcoder for channel 3 from 192.168.1.30 (encoder=remux, resolution=, deinterlacer=, bitrate=0)
2021/11/15 18:31:49.487127 [HLS] Probed live stream in 265.6011ms: mpeg2video 720x576 tt 1599609bps
2021/11/15 18:31:51.302401 [HLS] Session ch3-dANY-ip192.168.1.30 started in 2.639910911s
2021/11/15 18:32:10.295828 [TNR] Opened connection to 1252EA18/1 for ch72 7TWO Perth
2021/11/15 18:32:10.298625 [HLS] Starting transcoder for channel 72 from 192.168.1.30 (encoder=remux, resolution=, deinterlacer=, bitrate=0)
2021/11/15 18:32:10.452932 [HLS] ffmpeg: ch72-dANY-ip192.168.1.30-remux: [mp3float @ 0x7fab01820000] Header missing
2021/11/15 18:32:10.822934 [HLS] Probed live stream in 523.503397ms: mpeg2video 720x576 tt 923248bps
2021/11/15 18:32:11.150513 [HLS] Stopping transcoder session ch72-dANY-ip192.168.1.30 (out: 0s, finished: false)
2021/11/15 18:32:11.150918 [HLS] ffmpeg: ch72-dANY-ip192.168.1.30-remux: [mpegts @ 0x7fab01808200] Dropped corrupted packet (stream = 1)
2021/11/15 18:32:11.150935 [HLS] ffmpeg: ch72-dANY-ip192.168.1.30-remux: [mpegts @ 0x7fab01808200] Dropped corrupted packet (stream = 2)
2021/11/15 18:32:11.155792 [TNR] Closed connection to 1252EA18/1 for ch72 7TWO Perth
2021/11/15 18:32:12.162674 [TNR] Opened connection to 1252EA18/1 for ch72 7TWO Perth
2021/11/15 18:32:12.165651 [HLS] Starting transcoder for channel 72 from 192.168.1.30 (encoder=remux, resolution=, deinterlacer=, bitrate=0)
2021/11/15 18:32:12.538984 [HLS] ffmpeg: ch72-dANY-ip192.168.1.30-remux: [mp3float @ 0x7f7c5a020600] Header missing
2021/11/15 18:32:12.955673 [HLS] Probed live stream in 789.360463ms: mpeg2video 720x576 tt 1205462bps
2021/11/15 18:32:15.494983 [HLS] Session ch72-dANY-ip192.168.1.30 started in 4.292667996s
2021/11/15 18:32:15.507647 [ENC] Starting encoder for ch72 in /Volumes/TV_DISK/TV_FILES/ChannelsDVR/Streaming/ch72-dANY-ip192.168.1.30-2037683465/encoder-1-1057915266 at 1 (1.209000) (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=8000 segment_size=0.01)
2021/11/15 18:32:15.515895 [HLS] ffmpeg: ch72-dANY-ip192.168.1.30-1-----8000-0--0-0--blend-false-false-0.01: [mp3float @ 0x7faa4d81f400] Header missing
2021/11/15 18:32:31.691033 [ENC] Request for 1 is for different transcoding parameters at 8mbps
2021/11/15 18:32:32.546999 [ENC] Stopped encoder for ch72 in /Volumes/TV_DISK/TV_FILES/ChannelsDVR/Streaming/ch72-dANY-ip192.168.1.30-2037683465/encoder-1-1057915266 after encoding 1 to 17
2021/11/15 18:32:32.550685 [ENC] Starting encoder for ch72 in /Volumes/TV_DISK/TV_FILES/ChannelsDVR/Streaming/ch72-dANY-ip192.168.1.30-2037683465/encoder-1-3413291431 at 1 (1.209000) (encoder=h264_videotoolbox, resolution=576, deinterlacer=blend, bitrate=8000 segment_size=0.01)
2021/11/15 18:32:32.558497 [HLS] ffmpeg: ch72-dANY-ip192.168.1.30-1-h264-aac-copy--8000-256-576-0-0--blend-false-false-0.01: [mp3float @ 0x7fe0e5018e00] Header missing
2021/11/15 18:32:32.560530 [HLS] ffmpeg: ch72-dANY-ip192.168.1.30-1-h264-aac-copy--8000-256-576-0-0--blend-false-false-0.01: [mp2 @ 0x7fe0e6815200] Header missing
2021/11/15 18:32:32.560570 [HLS] ffmpeg: ch72-dANY-ip192.168.1.30-1-h264-aac-copy--8000-256-576-0-0--blend-false-false-0.01: Error while decoding stream #0:1: Invalid data found when processing input
2021/11/15 18:44:03.280845 [NAT] Successfully mapped port 8089 using upnp
