5.6.5 - slower channel changing?
I recently noticed that changing channels feels slower. I just timed it with a stopwatch app several times, and it's almost exactly 4 seconds.
I really feel like it used to be faster?
I'm on the latest Flex Quattro firmware 20230505, and latest Apple TV OS.
I'm using a 1gbe wired ethernet cable, so wifi not an issue here. Latency to the internet is under 10ms, and much less on the local LAN.
Any ideas here please?
Which channels? PRIME/Cablecard? ATSC1? ATSC3?
These ones - Freeview HD channels in the UK
Can you submit diagnostics from the app immediately after slow tune
Thanks - done :+1:
Any ideas here please @tmm1 ? Any other logs I can provide?
I need HDHR device id to find the diagnostics
12601B3E
Can you make a 30s recording from the channel and share it
Sure - can I attach a video here?
Yea if it lets you or else email to [email protected]
I need a tuner capture from the hdhomerun
Ok, here it is Dropbox - v101.mpg - Simplify your life
Thanks
Does this recording help @tmm1 ?
I see the same thing on my setup, I’m using the standalone Channels for HDhomerun app (not DVR). Don’t think it’s for slower recently but has always taken about 4 seconds to tune to a channel.
Apple TV 4K (2nd Gen) tvOS 16.6
HDhomerun Connect Duo 20230719
Please can I ping you on this again @tmm1 - did the linked video help? I'm hoping there's a fairly simple bit of buffer tweaking in the code to rectify this.
