Categories == Movie
OriginalDate > 1979-12-31
OriginalDate < 1990-01-01
You may want to pause this advanced pass and manually pick the ones you want to record because it finds hundreds of movies.
Categories == Movie
Good one.
Tip for creating advanced passes that could start scheduling and recording hundreds of things.
Before you save the advanced pass, add something like the following so it doesn't find any hits.
Channel == 0
or
Title == q7zx
Save the advanced pass, pause it, then edit it to remove the above and save again.
You now have a paused advance pass that didn't and won't record anything unless you unpause it.
That's a great tip, I didn't think of that.
I like it and will use it from now on.
Thanks for sharing.
Additional filtering to reduce the number of movies:
80's Comedy Movies:
Categories == Movie
Genre == Comedy
