If connected to a local HDHR Device and a remote DVR the apple tv app will still open with just the local tuners at first, minimizing and opening up again will force a refresh on most occasions and fix the issue.
New team passes created through the apple tv will only give “end time” options, stating that the program is live. I’ve had this happen a few times and once the pass is created you can go back into it and change the start time as needed.
using a remote connection if you double tap play to go to last channel it will give a buffer circle, I tried a few times and pressing play would get the video going but the buffer icon remained. Diagnostics were submitted but this may be a case where the pi just under powered and gets hung up.
With a local tuner and remote DVR I don’t get all of my local CC channels in the guide, possibly having to do with it being a duplicated channel name as the remote DVR channel (although its still a different number). The missing channels will still show up in the channel list for that tuner under the settings tab.
