Could you clarify how you have your tabs setup and how you're navigating to the view?
I've been testing on a Samsung Galaxy S21 Ultra 5G running Android 14. I have Enhanced Library enabled. When I open the app, it starts on the Library tab, and then I tap the Collections button, which shows my collections in creation order.
Aha! From the Library tab, if I instead navigate via Movies > Collections > More, or TV Shows > Collections > More, the sort is alphabetical.
That did the trick, thanks! Library Collections are now sorted correctly everywhere on Android.
Any timeframe on when this change is going to be implemented (assuming it still is)?
Also wondering if poster collections can be changed to portrait vs the landscape currently used. There are tons of poster collection images out there, but not in the Channels layout style.
