I have two questions I wanted to see if someone could answer.
First, when you are scrolling through the guide, and you reach the bottom of it, there is no way up set up for it to then go back to the top of the guide? Because it's so annoying to have to scroll all the way back to the top to go through it again.
And second, when going into the Channels Scanning. And then hitting the edit button, what can I do in here, other then rescan individual channels?
I see they have the channel number with an arrow under it, what does this do? Can I edit the numbers?
