A recording is going to be skipped tonight
So looking at up coming recordings. I have 3 xfiles that record from 10-11, 11-12 and 12-1. For some reason tonight, the 11-12 is not scheduled to record. I thought maybe it already existed in the library, but it does not.
Why would a pass skip a recording?
If it was already recorded and deleted. You can change that behavior by editing the pass on the web UI under advanced mode, then check Re-record Deleted
Either because it doesn't meet the criteria in your pass or it thinks it previously recorded that episode.
Click on the # of recordings on your pass
Screenshot 2021-08-18 at 17-04-50 Channels Passes
then see what it shows in there for that episode
As soon as I clicked that box, it fixed the issue. Thanks for the help.
