I've noticed that the ABC 7 live stream, channel 6001, streams all primetime shows 3 hours later. ABC shows through the antenna will start at 7pm, but ABC live stream shows start at 10pm. Is anyone experiencing the same issue and is there a fix for it?
It sounds like you're watching the TVE west coast channel. You should have an east coast version as well.
I tried the east coast version and it's 3 hours behind as well.
