Still relatively new, I’ve been running channels since February. For the last month or so, system is unwatchable if recording 2+ shows simultaneously — video pauses, tuner is unreachable, or web UI can’t see the DVR. It’s been suggested that HD is bad, but all works perfectly when server is idle and CHKDSK finds no errors.
I’m running on RPi4 4MB with WD HDD 4TB. RPi is tethered to router. All sources are TVE (YTTV and Philo).
Would SSD be capable of recording five shows at once? (It’s a wife thing.) Is the RPi able to handle the load? Is there anything else I can try? My wife wants to go back to separate apps for our sources if the problem isn’t fixed.
