@turtletank I will start by start by saying the challenge I'm having is so unique, it may only apply to me. I don't want to request development for such a small audience. But with the newly created ADBT Thread dedicated to DirecTV, figured I would open discussion.
I've been testing my Osprey Boxes with ADBT for a few months. It works rather well, but I have to use a work around. It seems ADBT needs to verify the declared Package Name is installed before continuing with the rest of the tuning process. The Osprey does not have an installed app. Instead it uses the System App com.att.tv.openvideo baked into the Osprey Firmware.
I bypass this challenge by selecting a random installed app during my Channel setup, then use a custom config to manually target the "openvideo" system app. Is there any way to use a System App as Package Name? Possible to skip this verification of installed, and just trust the declared (manual input) package name is good?
Again, this is not a show stopper for me. The bypass I'm using now works. Appreciate all you do.
from ADBTuner, I recall it was fairly trivial, since that value is already available as an internal variable.
