I have heard that new ONN boxes are being released.
I'm glad i got mine when they were released.
That one does not but the m3u8 link does work in VLC but it does not show anything when I hit view in ADBTuner
The error message indicates that it’s redirecting to /hdmi4/ with the trailing slash at the end (you are using /hdmi4 when it should be /hdmi4/). What happens if you use that URL? I don’t know anything about MediaMTX, but it looks like it supports MPEG-TS streams so make sure you use whatever URL maps to that format.
It is not case-sensitive.
Did you ever figure this out? I don’t know much about Portainer.
That can be quite useful indeed. I only had to reboot one of my sticks once but a lil less of a headache than using adblink and doing it from there
I agree! That would be a very nice feature.
In the mean-time, I have my tuners connected to this:
I'm not bright enough to know how to do that. My solution is not quite as sophisticated.
Any solution that works has a level of sophistication. :wink:
The most recent development version (20251228-2) has been marked as stable and is now available via turtletank99/adbtuner:stable.
Changes since the last stable release:
  • Added support for "keep active" commands within custom configurations. This provides a method to premptively clear "are you still watching" prompts.
  • ADBTuner will now reference the entire list of installed apps while allocating tuners so first-party Android apps can be launched.
  • Added new ||TARGET_DEVICE_IP_ADDRESS|| variable for use in custom configurations. This variable will be populated with the IP address of the target Android device.
  • The "Channel Number" field has been renamed to "Display Number" and is no longer used to sort channels in generated m3u files or in the administrative interface. This provides the ability to use non-numeric channel identifiers (ex. 10-1).
  • A dedicated "Sort Order" field has been added for each configured channel. When migrating from older versions of ADBTuner, this sort order will be initially set using the old "Channel Number" field.
  • Added new "keep in foreground" option linked to the "Keep Alive Package" feature associated with each tuner. If this box is checked, the defined app will be kept in the foreground waiting for ADB commands. This can improve tuning speed, but is not recommended for apps that are always playing video when they are open.
  • Profile screen ("who's watching") string matches and related commands can now be configured as part of custom configurations ("tune_match_text_commands").
  • Misc. bug fixes and improved logging.
If anyone runs into any issues please let me know. Thanks!
Unfortunately, this is not an open source project, so no license has been given to redistribute this work (all or part, modified or not).
My apologies I was not aware
A new development build (20260222-2) has been released that includes the following changes:
  • Per request: Added volume controls and a reboot button to the modal streaming endpoint preview window in the admin interface.
@tobeaking I saw the screenshots you posted earlier and while I think they looked awesome, it just isn't a direction I would like to take with ADBTuner.
ADBTuner has a pretty robust API (/api/docs) and you are more than welcome to start a new project that uses this API to provide an alternative administrative experience. If that is something you decide to take on and there is anything I can do to assist, please let me know, I'd be glad to help.
Dang it! I was just going to pick up a few of those. It appears that there are none to be found through Walmart.
Now, I notice some popping up on eBay for twice the price...:roll_eyes:
Keep an eye out. They were out of stock in my area, then came back for a small little bit.
These features are fantastic and appear to be working well in testing on my setup. Thank you so much!
Looking in logs I see this quite frequently, is this a normal entry and part of some internal process? I have 4 tuners added to ADBTuner, just making sure there is not something I've misconfigured.
I think that's a logging bug. You should have log entries above and below that block that would explain why the tuner is locked. Something like tuner_management - Reserved Tuner for maintenance or ADB: Preparing com.package.name for future tuning operations.
Yes, I see those above and below after the keep alive is run. Seemed like locking an N/A tuner was odd. Thought maybe my database or something was corrupted. I'll just ignore, or provide more info to you if needed. Thanks
Hi everyone, I am newer here, and I am definitely feeling in over my head. This project looks neat and I would like to give it a try. However I am no programmer but I feel like I should be able to do this and I cant even seem to get through the basic installation to get to the web interface.
Maybe there is a post about this on here but I havent been able to find one that helps, if there is, please feel free to direct me to it. I am running on windows 11 and have docker desktop installed. I tried running the installation code via docker compose using "docker-compose.yml" and I get "no configuration file provided: not found" in my terminal window when searching for the configuration file. I have tried putting the .yml file in different folders and navigatinig out to it using my cmd terminal with no luck each time.
Is there anyone who has the patience to tell me like a 3 year old where I have gone wrong lol? Thank you in advance for any advice.
Have you already purchased your HDMI encoder and streaming sticks?
If you install OliveTin-for-Channels, you'd be able to install this project, and many others pretty easily. Carefully follow the directions here to get it installed:
OliveTin's Project One-Click is accessed from the "hamburger" icon on the OliveTin Dashboard. Pretty much every know CDVR extension can be installed from there:
