I would like to update to the development build you recommend but I am a real newbie WRT to Docker. What commands do I need to execute to update my current ADBT docker image to the development build without losing my current configuration? Thanks.
For some reason I can install ADBTuner on my Synology NAS, but it continues to fail/restart. It was working great before. I decided to update to the latest version. Now I can't get the latest (or any version) to run in Docker after pulling the image from Docker Hub. It installs, but it tries to restart over and over until it stops. Any help is appreciated.
I get this in the log:
It looks like you forgot to setup a docker volume, or mount an existing one, to store the configuration.
The easiest way to do this would be to follow @anon38303228's recommendation and export your channel list, find/replace the configuration UUID in that text file, and then import (choosing the option to delete the existing configuration).
Honestly, I just install it from Portainer and it worked previously. When I uninstalled the last version, I clicked an option to "remove non-persistent volumes". Maybe thats an issue.
How would I mount an existing one? No idea how all the behind the scenes stuff works. I know Synology and their folder structure is different than others.
Hey, this set up looks promising for me to use.I have a DIRECTV Stream subscription that I was wanting to integrate into Channels. To clarify, would I need a FireTV Stick since it uses Firestick deep links? Does this also require ADBTuner?
Encoder question
-If you were going to start with this project today with a limited budget:
what encoder would you buy?
What streaming device would you buy?
works with many streaming devices. many of us that use directv, use directv's older 'osprey' boxes as it simplifies things a tiny bit.
linkpi enc1v3 is likely best bang for buck since it can be upgraded to a 2nd input with a cheap hdmi-usb.
they have a mini version limited to 1 input for less, but 1 tuner will quickly lead to you needing at least a 2nd. (padded recordings on different channels)
limited budget would probably suggest an onn box from wallyworld,
biggest thing is deciding the channels and service provider, then going from there according to your preferences and searching the thread for other's experience in that combo.
edit; my bad, did't realize what @k_evon88 was replying to.. I have yet to play with his new tool, but I suspect you can use it's outputted epg and m3u with other custom channels apps. and someone please correct me if i'm wrong, but I belive it's firestick (style) deeplinks, and firestick runs (ran) on android.
Thought I'd post a follow-up to my Hulu tuning problem/question. Once I figured out how to update to the development version I have not seen any tuning problems since. I do have one question. If doing a "match text" function are the matches case sensitive?
By chance would there be a way to use the custom config option to connect to the Spectrum app on my Onn stick (Google TV), to restore my local ABC? I was successful in using it to get MSNBC (MNNOW) app to launch. I have an external encoder.
Do you know if the Spectrum App responds to Deep Links?
Sadly there is no Spectrum app for Google TV. If I suggested as such, I misspoke.
So, I am trying to install ADBTuner to use FDL with. I've got the endpoint correct, on Android 11, but the Availability is grayed and not blue.
I also didn't get any virtual channels thru Project One click.
Suggestions appreciated.
Good progress. It'll be blue when there's an active stream -- gray is fine with no active stream, when the other two are green.
Let's thread jump again, and go here to start figuring out what needs to be done next:
I'll read and digest the thread and see if I can get it going. Wednesday's are my busiest day so could be Thursday before I start execution. I'll post back if I have questions. Thanks for the pointer.
BTW (off topic), ah4c has been rocking the Olympics utilizing all 3 Osprey's.
I am trying to use my MediaMTX and my BlackMagic Quad Decklink.
I am currently getting the following error and trying to figure out what it may be looking for
Just a quick PSA. For those looking at getting Onn 4K Plus boxes (or any Onn box really), they have been very low or absent in stock lately. This is somewhat related to an exodus from FireTV sticks after Amazon's lock down.
Does this mean that Amazon disabled use of ADB or something that would prevent using it with ADBTuner?
@JT-DFW Just sharing a trend for those in this thread who rely on cheap streamers for tuners. Onn 4K stock has been spotty.
I'm not aware of any impact to ADB on FTV devices right now. Seems the Amazon recent changes focus on piracy. Just wanted to share for anyone getting into ADBT, looking to buy some streamers soon.
