I use it...and it still works
If anyone gets past your router firewall, you're hosed. If they got into your server with malware or whatever, you're hosed. Launching a local adb command script from a docker container on your LAN has nothing to do with whether you're hosed.
I get that you want this to be easy for new folks, but the security argument against scripts is specious. Just say hey, I don't want to confuse new folks and leave it at that.
Tl;dr the container is not a sandbox.
It really doesn't seem fair to push for me to intentionally add security flaws because I should "trust the users" while at the same time suggesting that ADBTuner is insecure.
ADBTuner's source code has never been obfuscated. it's sitting right there in the container. Many people have reviewed it. It can easily be audited from both inside of and outside of the container it runs in. An open source license and a public Github project does not inherently mean that something is more secure or more trustworthy.
I have accepted some security risk to make things more convenient for the users. I added a REST API so people can easily automate most of what ADBTuner does. I added "configurations" so people can customize the commands that run on linked Android devices.
I know it's just a stupid app that like 8 people use that sits quietly on a local network 99.999% of the time. I know it's not the most secure piece of software ever written. I just drew a line at letting any networked device run any shell code it wants in the container.
I'm honestly surprised that this is even slightly controversial. If anyone actually cared about this project, something like this would result in a CVE with a CVSS score of 10 popping up the next day. Containers are not considered to be a security boundary and it could be used as a path to execute code on the host machine itself.
I can't assume that every user is going to bolt on their own security, most people will just run it without giving it another thought.
I don't really have anything else to say on the topic. I don't think it needs to be re-litigated on a weekly basis. I don't pop into threads for other projects to criticize the project and the author while promoting my own alternatives. I would appreciate the same. Thank you.
I pushed a new development build 20260815-1 this morning. It adds support for ordered command arrays within configurations. @babsonnexus
As I am not a coder and just an enthusiast who enjoys tinkering with all the wonderful solutions on this forum, I will say I appreciate and support everyone who wants to maximize the capabilities of all these projects as the tinkerer in me is never satisfied with the status quo and always wants more.
I also recognize that except for the Channels Dev team, everyone on here who is contributing is doing this at no cost to us users. Do I make suggestions to the contributors. Absolutely, I suspect they appreciate other peoples perspectives as they truly want to continue to improve their project. But I also believe that, because I don't pay for the projects I am enjoying, that after giving my suggestions, I have to step back and respect the contributors decision to incorporate, ignore, or shelve for later my suggestion.
Truly, I wish I had the skills to build my own project, but I'm too old and the wife won't let me sit in front of the computer enough to try and learn all I would need to do something like that.
I'm not criticizing you or the project, I'm simply saying that you cannot use security as an argument against scripts.
Confirmed in both positive and negative testing, thanks!
@Bobby_Vaughn, please be aware of these changes and functions for import.
@turtletank, I loaded the developer version 20260808 about a week ago. Compared to the previous stable version, this is a major improvement on the user interface... much more structured and clean...thank you!!! It's great.
I haven't played with the script commands yet... planning to do that soon... excited to see if that handles all that I'm trying to do... I think it will.
I noticed on the older stable version that putting any non-integer delays showed up as an error in the logs... that's why I've just been using the integer delays. I noticed in your example you used 0.25 seconds... may I assume you don't see any errors in the logs when using non-integer delays?
I noticed today that you dropped another revision 20260815. Are these just fixes, or additional features? [EDIT] Never mind... I saw you answered this question in another post... new script features... awesome...thanks.
Thanks so much for building the ADBTuner app...it definitely expands the capability of channels.
Good eye. I fixed that a few weeks ago. The intention was to support decimal values there, but I accidentally converted them to integers.
I set everything up from scratch yesterday:
- LinkPi ENC1-V3P with latest firmware + Onn 4K Plus (Android/Google TV)
- turtletank99/adbtuner:stable installed on NAS, latest Configuration and ESPN Stations imported
Endpoint and Android connections both show Successful in ADBTuner.
However when I try to preview the main ESPN station in ADBtuner I have a problem. Watching on the LinkPi I see:
- ESPN logo (E and "ESPN") plays, but then ONN returns to device home screen
- I continue to see commands go through but no longer in the app so it navigates me to the Google Services screen and stops.
Confirmed working manually: signed into ESPN via Xfinity and ESPN directly on the Onn, and the live feed plays fine — first item on the ESPN home screen.
Is this consistent with a wrong package name or launch command, rather than a navigation/button-sequence issue? How can I confirm what's actually being sent to launch the app?
Thanks for any guidance and for the great app.
Whose configurations & stations did you import?
NAS info?
How did you install ADBTuner?
Did you try to view in Channels?
I'm really hoping you used Project One Click to install.
- Used these configuration and station files
...github.com/babsonnexus/hdmi_encoder_native_apps
...github.com/babsonnexus/hdmi_encoder_native_apps/tree/main/adbtuner_native/stations - Synology DS1019+
- Installed using Synology container manager and .yml file below (seems to work)
- Have not tried Channels integration yet since I figured it wasn't ready
- No didn't use project one click but very open to starting over (link?)
docker-compose.yml:
version: '2'
services:
adbtuner:
image: turtletank99/adbtuner:stable
restart: always
init: true
volumes:
- /volume1/docker/adbtuner/config:/app/.config
ports:
- "5592:5592"
Here's a screenshot of my ESPN channel. I suspect you have the wrong package selected. That was my issue when originally set up. You can use the Status Page (json) on the advanced dropdown on the ADBTuner to see all the package names on your devices. It takes about 50 seconds for all the commands to go thru.
Thanks. Here's my station settting. Looks similar to yours but with the order of package names reversed. In the Status Page I see com.espn.score_center but no com.espn.gtv - do you see the same?
ESPN packages:
ONN: com.espn.score_center
firestick: com.espn.gtv
On the channels page, select preview on the channel and it will show you what it's doing. You don’t have to look at the Link Pi viewer as it shows you what it's doing.
Here's a screenshot (wish I could video for you)
Edit. If you go to configurations, you can view the espn config and see all the steps to open espn. There are 50 step downs to get to bottom of the app where all the espn linear stations are. Using the default config, it'll take over a minute to open so it's doing something but you can’t see it. I’ve cloned that config and adjusted for times and steps for my setup.
My provider name is 'native' not 'app.espn'
I’m not sure if that makes a difference but change it and try.
My setup was done with Project One Click
That's because you installed ALL native channels through Project One-Click. It does not apply to people installing manually.
Channels should give that guy that developed Project One Click a Lifetime Subscription!!
It's better than the KISS principal.
By your screenshot and docker compose, I can see you are on the stable aka latest tag. You need to be on the the development one because there are features that HENA uses, especially for ESPN, that are not available in the general release. This is discussed on the Wiki:
Awesome - that did the trick! I am up and running just in time for some of my favorites!
When ESPN dropped TVE support I was really bummed. Even though I could watch it live on my computer, I virtually never did as I am hooked on the Channels environment and streaming sports (even with a cloud DVR) just doesn't compare. Commercial skip and instant skip forward and back over gigE just can't be beat for me. I often watch football games in < an hour.
Many thanks for the app and support! I've been thinking about this for some time, but it took me less than a day to get up and running. Well done @turtletank @babsonnexus and friends!
