I’m not giving up just yet, but after a quick look there is no obvious way to automate channel changes on either the ADTH or Zinwell tuner.
Even if we were going to fall back to just using remote inputs, neither device provides an easy way to do that.
The Zinwell tuner will accept channel numbers, but it ignores non-numeric characters so you can’t enter a specific sub-channel EDIT: If you time it right the hyphen is filled in automatically so remote command control should be doable.
The ADTH doesn’t accept any numeric characters as input. There is one dialog where you can select a number, but only via arrow keys.
I will take another look though, but if I can’t find anything that is really effective, I will probably just return both devices and just stick with ATSC 1.0 via HDHomeRun because that “just works.”
At the moment, I don’t have anything in place within ADBTuner to monitor the status of a stream once it has started. I will have to think about this a bit.
