are there any more of these commands for other channels?
does anyone by any chance have the channel list of xfinity channels that you can share with me? I would really appreciate it
There is no list open a webbrowser login to your XFINITY Stream... go to livetv all channels click on a channel you want to watch and you will see the link.
Here is what the link looks like ... example ... I just replace the title with the channel name...
[type or paste code here](https://www.xfinity.com/stream/live/Watch-Chassie-Post/7728061817102576105/KGWHD)
Replaced Title ...
(https://www.xfinity.com/stream/live/KGWHD/7728061817102576105/KGWHD)
ooh okay thanks and what do i put for package name? Also I have an xfinity flex box and a firestick which would you say is best? thanks
I have no clue what an XFINITY Flex box is. Firesticks work great.
okay and what do i put for package name?
click on ADB tuner it will show you what packages are Installed you will see xfinity everything is there if you are ready to go.
Do you even have the stuff to make this work or are you just asking ?
im sorry where so i click in adb tuner to see the packages? Im looking but there is no clicking available at least not that I can see?
When you add a Channel. Click on Select From Installed.Make sure to check Enable Compatibility Mode for this Channel ... when you add Channels.
Firesticks work great. I like the 4k Max version 2 ones for the speed and WiFi6 ability.
once he’s ready for an HDMI encoder I’m sure we’ll see 4 new threads about it
yes i do bro
I was going to post something yesterday in the ah4c thread but I will post it here.
I am more than willing to try and help you set something up if you wish.
Don't mean to upset/frustrate you but...
I think everyone is having a hard time following what you have and what you want to do because you keep jumping all over the place in all kinds of threads and talking about ALL different streaming subscriptions each possibly needing slightly different setups.
If you are interested I can create a new thread where we can discuss what hardware you currently have and then FOCUS on setting up a single streaming service and get everything working. I would recommend one that is simple to start that will work with ADBTuner because it is usually easier to initially work with.
Currently I am running Philo/Onn4k/ADBTuner, Spectrum/AppleTV4k/ah4c all fed into a LinkPi 5 port encoder that communicates with a RasberryPi4 ChannelsDVR Server
Let me know if you are interested.
I am also confused because initially he stated he was a XFINITY Subscriber ... but then I saw threads on HULU DirectTV ... slingTV etc ...
At this point, I'm convinced he's either very rich or is a bot
My thought was that he’s trying to build a Mega Channels DVR server that's collected every channel and stream in the world, by leveraging a pool of shared subscriptions, IPTV, FAST channels, YouTube Live, Hulu, Tubi, Fubo, AppleTV+, PPV, on-demand and all other online content available anywhere, and combining it all into one tremendous, unified Guide, intended to be offered to a large group of friends and family around the globe.
I’m probably totally off-base though.
ok thanks
Been out all day and just saw this. I will assume this is an "ok thanks, I will let you know if I decide to do that."
If it is an "ok thanks, Let's do that then send me a DM to let me know to start a thread on the subject"
does this work with hbo max?
no
