In a nutshell ADBTuner tunes the app on an android device which outputs via HDMI to an encoder which then streams video to Channels. So yes the app will be on when it is being used. ADBTuner will open the app if it is not already open and theoretically turn to the correct live channel.
so i need an encoder? Is that why its not working? They are all m3u8
Yes you do. Yes that’s why. And you really need to read the beginning of this thread. And you need to also read up a little on HDMI for Channels.
This post from a couple of weeks ago may also clear things up a little.
And now I understand why you asked this. It actually doesn't really have anything to do with TVE. TVE is an authentication method which is bypassed using this method as the apps on the devices take care of authentication.
man... my encoder is ffmpeg and streamlink why do i need a hardware encoder?
It is how you convert your hardware Android device’s physical hdmi output to a video stream format Channels can use.
there has to be a way to take this video stream and remux or transcode without a hardware encoder. I mean the streams are m3u8 as it is, why would it need encoded? why not have chromium stream it and the software remux or copy?
The video stream is the HDMI output of the streaming device that ADBTuner is talking to (such as Chromecast, Onn, FireTV). Those m3u8 links you mention are to tell the appropriate app on that streaming device (Youtube TV perhaps) what video to send to the HDMI output of the streaming device. There has to be a piece of hardware with an HDMI port to connect to the HDMI port on the streaming device.
why did you delete that?
- Connect your device to your computer.
- Open a command prompt.
- Run
adb devicesto make sure your device is properly connected. - Run
adb shell am start -a android.intent.action.VIEW -d "https://tv.youtube.com/watch/6T7reIiHVnA".
This will send an intent to the device to view the given URL. If the YouTube app is installed and registered to handle these types of URLs, it should open the link.
#!/bin/bash
URL of the YouTube video
url="https://tv.youtube.com/watch/6T7reIiHVnA"
Use youtube-dl to download the video and pipe it to ffmpeg
youtube-dl -f best -o - "$url" | ffmpeg -i - [ffmpeg commands]
Do those m3u8 streams have DRM? If so, that’s why. The hardware encoder circumvents DRM in a way software cannot, or currently does not.
Thought I'd play with this while waiting on my encoder to arrive. Testing with Firetvstick 4K and this is as far as I can get:
from the logs:
2023-12-24 18:55:18.138 - lib.adb - ADB: Android Version: 9.0.
2023-12-24 18:55:18.156 - uvicorn.access - 10.0.0.145:52992 - "GET /admin/tuner/metadata?_=1703444104113 HTTP/1.1" 200
2023-12-24 19:01:17.796 - lib.adb - ADB: Connecting to device (attempt 1).
2023-12-24 19:01:17.929 - lib.adb - ADB: Connected.
2023-12-24 19:01:17.929 - lib.adb - ADB: 10.0.0.184 - dumpsys display
2023-12-24 19:01:18.019 - lib.adb - ADB: 10.0.0.184 - getprop ro.build.version.release
2023-12-24 19:01:18.095 - lib.adb - ADB: Android Version: 9.0.
2023-12-24 19:01:18.113 - uvicorn.access - 10.0.0.145:53254 - "GET /admin/tuner/metadata?_=1703444104162 HTTP/1.1" 200
Thoughts?
Sorry about that, I'm still figuring out how this is going to work. I thought the title "without hardware encoder" implied this could be done without one. I'll just wait for mine to arrive...
