Can you add an option to select the default channel as SD or HD when creating a new recording or pass using the default options?
Now whenever I create a new series pass using the guide or search option I have to login to the website after creating the pass and modify the pass to enter the HD channel number for the recordings.
It would be nice to have a default setting option to indicate whether the series should be recorded as SD, HD or ANY. Then there wouldn’t be a need to modify the passes I create using the default options and it would automatically select the correct channel number.
Thanks
