I go to the guide data editor (pencil icon), click “+” in the upper left, add a zip code. It shows it. Then, when I dismiss the dialogue, the additional zip code disappears.
Something I’m doing wrong? I don’t see a “save” option anywhere.
The additional zipcode is not saved. It only adds more station options, so you can click the pencil next to one of your unmapped channels to map it to the station in that zipcode.
Ok. Thanks.
Any downside to having added the same zip more than once?
ETA: I don’t have pencils next to my unmapped channels. Just “+” signs. Experimenting… So it looks like how this works is you add the zip code, then immediately map the individual channels?
Correct, click the plus icon not pencil.
If you leave and re-enter that display, the mappings don’t re-appear right away. I’m guessing that’s because the guide data hasn’t been fetched, yet?
There should be a spinner at the top while the mappings are loading in…
The ui in that dialog is a mess
