I have the Pluto TV Docker running on my Mac. I am trying to add the M3U to my Channels server, which is located on a Pi. Is this possible? If so, what is the IP address for the M3U when you add it? Thanks!
Yes it's possible. The IP address is the Mac's, assuming that's where your container is running.
So simple. It works. Thanks so much!
Note that if the ip address of your Mac changes, it will break. A static IP address is recommended to avoid that issue.
Or use the machine name instead of the IP address, then you don't have to worry about it.
