Adjust options is broken for recordings in progress
The adjust options button is not working now. If you select a recording in progress, then select manage and then adjust options it asks you if you want to record it again because it's already in your library. So something got broken because you used to be able to change the length of an ongoing recording with that button.
You have to go into the web admin to change the padding now.
Running latest Apple TV beta.
This should be resolved in the latest TestFlight beta:
Thanks for the quick fix!
