I had added a bunch of season passes and found the priority menu and was moving shows to the top so they would have a better chance of recording vs other shows I want to record, but they aren't as important as others. I realized it would be much quicker to move the few non priority ones "Down" than to move lots of passes up. (they appear to need to move one at a time on the web interface) When I try to move the few down below the others I want as higher, they do not move, they go right back to where they were in the list. Is that a bug or am I dragging them incorrectly? -Bill
I think it may be a bug. I just tried, and while I have no problem going from lower to higher, I was unable to go from higher to lower.
Of course, my attempts were in mobile Safari; I wonder if using a different browser would yield different results?
I tried on Firefox for windows. Moving up=great, Moving down=nope. Also just tried on Chrome for windows. Same, nothing can move down in the Adjust Priority screen. -Bill
I can move shows Down in Priority using the Android Client on my Shield device! So I guess its a BUG in the web client. -Bill
Confirmed, we'll take a look.
This was resolved in the latest pre-release:
