Feature Request: Ability to create rule for minimum OTA antenna signal strength
Use Scenario:
Non important recording (ex: old movies and shows with lots of reruns) I have Advanced passes set to record every movie meeting certain paramaters. However whether the gods smile or not effects my signal strength on some channels.
Important recordings (EX. new tv episodes that don't get re-runs) I have my OTA at top of source priority above my TVE. Obviously OTA reception often gets effected by weather. So by setting a minimum signal strength, if it fails that threshhold it would switch to my TVE source.
The hope is to reduce my ammount of"recording interupted" and poor video from bad signal
I am unsure if HDHR makes that info available in real tome to ChannelsDVR. Or if this is even possible.
