Not sure what happens when using antenna and 2 HDFX-4K (HDHomerun) recording the same show at the same time.
I record Prime Time shows by Channel using Advanced Pass to keep 3 episodes, and use a Series Pass to keep 30 epiodes.
Question: If the Advanced Pass and Series Pass are both set to run at the same time, what happens in regard to the tuners?
Does one tuner record and keep the 3 Advanced episodes, or does it overight the Advanced condition when there is a Series Pass set to record 30 of the same show?
Or maybe 2 tunes are used and record both Advanced Pass and Series Pass? If so, does it keep both?
Advanced Pass
Conditions
Channel == 5.1
Time CONTAINS 8pm
Time CONTAINS 9pm
Time CONTAINS 10pm
Keep Last 3 Only
Limit No Limit
And
Series Pass
Record All Episodes
Channel 5.1
Keep Unwatched and 30 Watched
