After ~5 updates, Server will not run and has to be installed
I am running the server in Windows 10. After every 5 or so updates, the server will not restart and must be re-installed. It will then work normally for about 5 updates.
Any suggestions?
Are you running as a Service or at logon ?
It is running as a Service. Thanks
Make sure your service is setup this way . . .
That is exactly how mine is. Keep in mind, I can reboot the computer, or start it manually after about 5 updates and it will not start unless I re-install.
Doesn't Channels keep abut 5 backups of updates? Is it possible once those are gone, it is causing me an issue? Just a thought to resolve this.
Thanks
I went to sleep watching my favorite channel.
I checked the next morning and my server had stopped on my Synology.
I went to the package center and uninstalled the software and re-install the program.
I then used a backup to restore y settings.
Anything in the logs?
I'm sure there may be but not talented enough to read them.
365293d7-e87a-4f92-8b14-c1388e748dcc.
I had the same issue on synology when i updated a couple of days ago
Any suggestions from the Channels Team?
