Ah4c question please
Hello I am trying to setup ah4c but I am stuck in the part where it says: "Specify the name of your LAN's domain", how do i obtain this? Thanks in advance!
You’ve been asked to stop spamming the forum, why do you keep doing it?
There is a thread for AH4C questions, you should use it.
You are all over the place post your questions in the thread of the one you are using ... CC4C, AH4C or ADBTUNER ... If you want to view telemundo or whatever post it in the thread of what you are going to use to view it then someone can guide you or help you along.
