AMC ch6086 TVE: Stream Not Available
AMC channel doesnt seem to work for me. I keep getting this error Couldn't generate stream playlist for ch6086-dANY-ip: TVE: Stream Not Available
Sundance working with no issue.
Same here. Philo is my provider.
Yep. My error is showing as not authorized. Philo & Hotwire (same error). Can’t find TVE stream online to see if there is an issue with the feed, but Sundance and IFC both work (I think those are all related).
I have the same issue with AMC only (Sundance & BBC okay); Philo is my provider. I logged into amc.com, but I cannot seem to find the 'watch live/now' link. I can only stream on-demand episodes.
Seeing the same error.
SUNDANCE, BBCA, IFC and WETV are working.
And no way to watch live at www.amc.com after signing in with my provider.
Sounds like the webstream is down.
I'm seeing the same issue here.
I have an open ticket with AMC Networks.
I wrote to them to ask whether the removal of the link from the AMC website to watch the live stream is temporary or permanent.
I will let you know when/if I get a reply.
Having the same issue here. I am on Spectrum TV.
Hi there,
Upgrade the latest pre-release.
The problem was just fixed.
I'm watching it now.
That did it. Working here now also.
Thank you.
I updated to the latest prerelease tonight and still no luck. I'm on Spectrum, and when I launch other channels they play fine. When I try AMC and IFC, the window launches and says "RECONNECTING..." and then the video area just goes away. Any ideas?
@JrSprad
Workin for me after updating pre release. I had to go into the the source. Then manage channels, then rescan. Then it worked.
It finally worked for me. I may have missed the rescan initially.
