AMC on TVE is not recording
Using Spectrum. AMC is not recording. It is returning the following error. Is anyone else getting this? Logs ID included below the error messages.
2026/08/24 03:07:31.908484 [ERR] Failed to start stream on channel 6086 via TVE-Spectrum: TVE: POST: https://gw.cds.amcn.com/playback-id/api/v1/livestream/6398764467112: 400 Bad Request: "{"success":false,"status":400,"error":"Asset is not available for country 'gr'"}"
2026/08/24 03:07:31.908484 [DVR] Error running job 1787551550-ch6086 The Walking Dead: Dead City: could not start stream on channels=[6086]: TVE: POST: https://gw.cds.amcn.com/playback-id/api/v1/livestream/6398764467112: 400 Bad Request: "{"success":false,"status":400,"error":"Asset is not available for country 'gr'"}"
4b88e5f4-3cd9-4182-bd43-b1a042e464cd
What country are you in?
Are you using a VPN?
USA. And no I am not using a VPN and all other TVE channels work fine.
For some reason, that station thinks you are in a different country. Try re-detecting that chanel.
I've tried that a couple times. Get the same error message. It's very odd. It's been working up until this past Sunday.
You can try removing the TVE source and recreate it. Before you do that, go to your provider's web site and see if you can stream that channel from there. If you can't, contact the provider. If you can, then removing TVE and adding it might fix it.
Can you watch at this AMC TVE website?
https://www.amc.com/tve
Does Support > Troubleshooting show all green checkmarks?
