bump
Why not just use software encoding?
Even using software encoding wont get me channel 13000 away from home and I have a very expensive gpu that I want to have a use for and while I have a core ultra 7 cpu software transcoding still takes up a lot of resources.
You could just do original quality. With bandwidth the way it is today i cant remember a time where i really needed transcoding. I just run with original quality (no transcoding in all scenarios).
My experience with Ubuntu is you don’t necessarily want the latest release. They frequently have missing gpu drivers and simply are not ready for mass release. Try using something older like Ubuntu 22.04 that has a more established kernel and drivers.
I totally agree with not using the bleeding edge version -- there's little upside. In addition, I would add that if you don't have a specific reason to use the Desktop version of Ubuntu, Server is a better choice.
so I set the following under settings>client and I get yes network on my pixel 8 yay.
However I still don't get channel 13000 away from home. I get the following error
2025/05/03 21:24:59.062804 [HLS] Starting live stream for channel 13000 from 174.204.135.188
2025/05/03 21:25:01.430189 [HLS] ffmpeg: ch13000-dM3U-playlist-fb42f6258f36-remux: [mpegts @ 0x3e91d4c0] DVB subtitles with multiple languages is not implemented. Update your FFmpeg version to the newest one from Git. If the problem still occurs, it means that your file has a feature which has not been implemented.
2025/05/03 21:25:01.430202 [HLS] ffmpeg: ch13000-dM3U-playlist-fb42f6258f36-remux: [mpegts @ 0x3e91d4c0] If you want to help, upload a sample of this file to VideoLAN File Uploader and contact the ffmpeg-devel mailing list. ([email protected])
2025/05/03 21:25:01.430206 [HLS] ffmpeg: ch13000-dM3U-playlist-fb42f6258f36-remux: [mpegts @ 0x3e91d4c0] DVB subtitles with multiple languages is not implemented. Update your FFmpeg version to the newest one from Git. If the problem still occurs, it means that your file has a feature which has not been implemented.
2025/05/03 21:25:01.430207 [HLS] ffmpeg: ch13000-dM3U-playlist-fb42f6258f36-remux: [mpegts @ 0x3e91d4c0] If you want to help, upload a sample of this file to VideoLAN File Uploader and contact the ffmpeg-devel mailing list. ([email protected])
2025/05/03 21:25:01.431062 [HLS] ffmpeg: ch13000-dM3U-playlist-fb42f6258f36-remux: [mpegts @ 0x3e91d4c0] DVB subtitles with multiple languages is not implemented. Update your FFmpeg version to the newest one from Git. If the problem still occurs, it means that your file has a feature which has not been implemented.
2025/05/03 21:25:01.431067 [HLS] ffmpeg: ch13000-dM3U-playlist-fb42f6258f36-remux: [mpegts @ 0x3e91d4c0] If you want to help, upload a sample of this file to VideoLAN File Uploader and contact the ffmpeg-devel mailing list. ([email protected])
2025/05/03 21:25:01.431069 [HLS] ffmpeg: ch13000-dM3U-playlist-fb42f6258f36-remux: [mpegts @ 0x3e91d4c0] DVB subtitles with multiple languages is not implemented. Update your FFmpeg version to the newest one from Git. If the problem still occurs, it means that your file has a feature which has not been implemented.
2025/05/03 21:25:01.431070 [HLS] ffmpeg: ch13000-dM3U-playlist-fb42f6258f36-remux: [mpegts @ 0x3e91d4c0] If you want to help, upload a sample of this file to VideoLAN File Uploader and contact the ffmpeg-devel mailing list. ([email protected])
2025/05/03 21:25:01.431152 [HLS] ffmpeg: ch13000-dM3U-playlist-fb42f6258f36-remux: [h264 @ 0x3e923000] sps_id 0 out of range
2025/05/03 21:25:01.493974 [HLS] Probed live stream in 2.430958188s: h264 1920x1080 tt 5736900bps
2025/05/03 21:25:02.159838 [HLS] ffmpeg: ch13000-dM3U-playlist-fb42f6258f36-remux: Last message repeated 95 times
2025/05/03 21:25:02.159858 [HLS] ffmpeg: ch13000-dM3U-playlist-fb42f6258f36-remux: [mpegts @ 0x3e91d4c0] probed stream 3 failed
2025/05/03 21:25:02.159864 [HLS] ffmpeg: ch13000-dM3U-playlist-fb42f6258f36-remux: [mpegts @ 0x3e91d4c0] probed stream 4 failed
2025/05/03 21:25:02.163480 [HLS] ffmpeg: ch13000-dM3U-playlist-fb42f6258f36-remux: [mpegts @ 0x3e91d4c0] Could not find codec parameters for stream 3 (Unknown: none ([139][0][0][0] / 0x008B)): unknown codec
2025/05/03 21:25:02.163496 [HLS] ffmpeg: ch13000-dM3U-playlist-fb42f6258f36-remux: Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (8000000) options
2025/05/03 21:25:02.163498 [HLS] ffmpeg: ch13000-dM3U-playlist-fb42f6258f36-remux: [mpegts @ 0x3e91d4c0] Could not find codec parameters for stream 4 (Unknown: none ([139][0][0][0] / 0x008B)): unknown codec
2025/05/03 21:25:02.163500 [HLS] ffmpeg: ch13000-dM3U-playlist-fb42f6258f36-remux: Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (8000000) options
2025/05/03 21:25:02.163503 [HLS] ffmpeg: ch13000-dM3U-playlist-fb42f6258f36-remux: [mpegts @ 0x3e91d4c0] Could not find codec parameters for stream 6 (Audio: dts (dca) ([130][0][0][0] / 0x0082), 0 channels): unspecified sample format
2025/05/03 21:25:02.163513 [HLS] ffmpeg: ch13000-dM3U-playlist-fb42f6258f36-remux: Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (8000000) options
2025/05/03 21:25:02.163515 [HLS] ffmpeg: ch13000-dM3U-playlist-fb42f6258f36-remux: [mpegts @ 0x3e91d4c0] Could not find codec parameters for stream 7 (Unknown: none ([160][0][0][0] / 0x00A0)): unknown codec
2025/05/03 21:25:02.163516 [HLS] ffmpeg: ch13000-dM3U-playlist-fb42f6258f36-remux: Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (8000000) options
2025/05/03 21:25:02.164151 [HLS] ffmpeg: ch13000-dM3U-playlist-fb42f6258f36-remux: [hls @ 0x3e952140] sample rate not set
2025/05/03 21:25:02.164163 [HLS] ffmpeg: ch13000-dM3U-playlist-fb42f6258f36-remux: [out#0/hls @ 0x3e94ca80] Could not write header (incorrect codec parameters ?): Invalid argument
2025/05/03 21:25:02.164164 [HLS] ffmpeg: ch13000-dM3U-playlist-fb42f6258f36-remux: [sost#0:4/copy @ 0x3ed27780] Error initializing output stream:
2025/05/03 21:25:02.164165 [HLS] ffmpeg: ch13000-dM3U-playlist-fb42f6258f36-remux:
2025/05/03 21:25:02.168195 [TNR] Closed connection to M3U-playlist for ch13000 playboy
2025/05/03 21:25:02.342149 [HLS] Stopping transcoder session ch13000-dM3U-playlist-fb42f6258f36 (out=0s finished=true first_seq=0 last_seq=-1)
2025/05/03 21:25:02.342155 [SNR] Buffer statistics for ch13000 playboy: buf=0% drop=0%
channel 13000 plays fine in vlc and in the android tv app at home on my onn pro
logs submitted.
82c3c185-7d4c-4fef-bb00-6883d216e4da
Please update ffmpeg so I can get channel 13000 away from home. thanks
I don't know what "channel 13000" is or why it would have so many MPEG-TS streams that aren't identified by ffmpeg. It sure sounds like there's something abnormal about the stream, but without a sample that's only a guess.
@techpro2004 This issue is with a third party source via Custom Channels. This source is provided by the community, and not part of Channels.
While we strive to do our best to make sure things work great, especially here within this community forum, these sources are just that, third party and not officially part of Channels.
So, while this community forum is absolutely the place to discuss issues with third party foreign sources for Channels, it's not appropriate to demand support for them, as they are not officially supported.
eric:
I will pm you the stream details for channel 13000. Just don't play it around any kids.
Maddox:
I am not demanding anything. I just figure if a simple ffmpeg update will fix my issue then it should not be too much to ask for it.
I just pmed eric
No, updating ffmpeg is not simple. We have many platforms we support and it requires extensive testing on each platform before we update ffmpeg on it to make sure there are no regressions on things that were previously working for folks.
Just curious, why not do limited testing and then list it under experimental features under settings>advanced so the community can test it and eventually approve or deny it. thanks.
Just noticed my linux based channels dvr server is on the 6.0 branch of ffmpeg. While I recognize it may be difficult to upgrade, that is quite old. What is the normal lifespan of an ffmpeg build on channels dvr?
This message is informational and not related to your errors. The same message exists in the latest version of ffmpeg.
Odd very odd. How do we fix this then?
