Is there a list of Android TV supported client devices?
Android TV are supported the only thing you have to be worried about is the Android Version.
Basically all Android TV devices are supported.
What is NOT supported are cheap TV streaming boxes running Android. There is a difference.
Decided to play it safe and ordered a NVIDIA SHIELD Android TV. Thanks for the advice.
