agree on giving it a try, but likely would encounter issues regardless until we get windows and linux playing nice.
FYI there are lots of directions on the web saying C:/directory, and that may work if other things get setup differently. but my experience as documented here says always go for /mnt/C/directory when using WSL(2) and Docker Desktop
forgot to mention that I'm not sure why it matters where the olivetin HOST_DIR is in relation to other containers. other than the adb keys persistance, but again, ah4c handes that, not olivetin. but somehow it seems too. (still nailing that part down exactly)
it may be one-click related, or another backend engine shared by both containers.
fyi at least on the osprey's you may have a stack of adb authorizations build up in the background (usually you can see them by pressing menu) but in your current state they may be there, but not showing. they need power cycled. then when their up, start/restart ah4c/adbtuner and make sure the current saved key is authorized.
This did it, thank you!!
Which "this" did it? Are you now running ah4c or ADBTuner?
I’m on ADBTuner and so far it’s working perfectly
@bnhf
Looking to move from Channel Numbers to deeplinks on my Osprey's in ah4c. I utilized Olive Tin Action to gather the m3u deeplinks data (P1C is great). Below are my current compose and environmental variables. What changes do I need to facilitate?
I have already made a backup of my channel number m3u's in case I need to revert.
version: '3.9'
services:
  # 2024.10.30
  # GitHub home for this project with setup instructions: https://github.com/sullrich/ah4c
  # Docker Hub home for this project: https://hub.docker.com/repository/docker/bnhf/ah4c
  ah4c:
    image: bnhf/ah4c:${TAG}
    container_name: ah4c
    hostname: ah4c
    dns_search: ${DOMAIN} # Specify the name of your LAN's domain, usually local or localdomain
    ports:
      - ${ADBS_PORT}:5037 # Port used by adb-server
      - ${HOST_PORT}:7654 # Port used by this ah4c proxy
      - ${WSCR_PORT}:8000 # Port used by ws-scrcpy
    environment:
      - NUMBER_TUNERS=${NUMBER_TUNERS} # Number of tuners you'd like defined 1, 2, 3, 4, 5, 6, 7, 8 or 9 supported
      - TUNER5_IP=${TUNER5_IP} # Streaming device #5 with adb port in the form hostname:port or ip:port
      - TUNER6_IP=${TUNER6_IP} # Streaming device #6 with adb port in the form hostname:port or ip:port
      - TUNER7_IP=${TUNER7_IP} # Streaming device #7 with adb port in the form hostname:port or ip:port
      - TUNER8_IP=${TUNER8_IP} # Streaming device #8 with adb port in the form hostname:port or ip:port
      - TUNER9_IP=${TUNER9_IP} # Streaming device #9 with adb port in the form hostname:port or ip:port
      - ENCODER1_URL=${ENCODER1_URL} # Full URL for tuner #1 in the form http://hostname/stream or http://ip/stream
      - ENCODER2_URL=${ENCODER2_URL} # Full URL for tuner #2 in the form http://hostname/stream or http://ip/stream
      - ENCODER3_URL=${ENCODER3_URL} # Full URL for tuner #3 in the form http://hostname/stream or http://ip/stream
      - ENCODER4_URL=${ENCODER4_URL} # Full URL for tuner #4 in the form http://hostname/stream or http://ip/stream
      - ENCODER5_URL=${ENCODER5_URL} # Full URL for tuner #5 in the form http://hostname/stream or http://ip/stream
      - ENCODER6_URL=${ENCODER6_URL} # Full URL for tuner #6 in the form http://hostname/stream or http://ip/stream
      - ENCODER7_URL=${ENCODER7_URL} # Full URL for tuner #7 in the form http://hostname/stream or http://ip/stream
      - ENCODER8_URL=${ENCODER8_URL} # Full URL for tuner #8 in the form http://hostname/stream or http://ip/stream
      - ENCODER9_URL=${ENCODER9_URL} # Full URL for tuner #9 in the form http://hostname/stream or http://ip/stream
      - ALERT_SMTP_SERVER=${ALERT_SMTP_SERVER} # The domainname:port of the SMTP server you'll be using like smtp.gmail.com:587. This is for sending ah4c alerts if tuning fails.
      - ALERT_AUTH_SERVER=${ALERT_AUTH_SERVER} # The auth server for the e-mail you'll be using like smtp.gmail.com
      - ALERT_EMAIL_FROM=${ALERT_EMAIL_FROM} # The e-mail address you'd like your ah4c failure alert e-mails to show as being from.
      - ALERT_EMAIL_PASS=${ALERT_EMAIL_PASS} # Gmail and Yahoo both support the creation of app-specific e-mail passwords, and this is the way to go! It's NOT recommended to use your everyday e-mail password.
      - ALERT_EMAIL_TO=${ALERT_EMAIL_TO} # The e-mail address you'd like your alert e-mails sent to.
      #- ALERT_WEBHOOK_URL=""
      - LIVETV_ATTEMPTS=${LIVETV_ATTEMPTS} # For FireTV Live Guide tuning only, set maximum number of attempts at finding the desired channel
      - CREATE_M3US=${CREATE_M3US} # Set to true to create device-specific M3Us for use with Amazon Prime Premium channels -- requires a FireTV device
      - UPDATE_SCRIPTS=${UPDATE_SCRIPTS} # Set to true if you'd like the sample scripts and STREAMER_APP scripts updated whether they exist or not
      - UPDATE_M3US=${UPDATE_M3US} # Set to true if you'd like the sample m3us updated whether they exist or not
      - SPEED_MODE=${SPEED_MODE} # Set to false if you'd like the target streaming app to be closed after each tuning cycle (limited script support).
      - KEEP_WATCHING=${KEEP_WATCHING} # In supported scripts, set the delay before resending a tuning deeplink to prevent "Are you still watching?" type messages. Examples: Use 4h for 4 hours or 240m for 240 minutes.
    volumes:
      - ${HOST_DIR}/ah4c/scripts:/opt/scripts # pre/stop/bmitune.sh scripts will be stored in this bound host directory under streamer/app
      - ${HOST_DIR}/ah4c/m3u:/opt/m3u # m3u files will be stored here and hosted at http://<hostname or ip>:7654/m3u for use in Channels DVR - Custom Channels settings
      - ${HOST_DIR}/ah4c/adb:/root/.android # Persistent data directory for adb keys
    restart: unless-stopped
**strong text**
TAG=latest
DOMAIN=local
ADBS_PORT=5037
HOST_PORT=7654
WSCR_PORT=7655
IPADDRESS=10.0.1.65:7654
NUMBER_TUNERS=3
TUNER1_IP=10.0.1.76:5555
ENCODER1_URL=http://10.0.1.34:8090/stream0
TUNER2_IP=10.0.1.29:5555
ENCODER2_URL=http://10.0.1.34:8090/stream1
TUNER3_IP=10.0.1.77:5555
ENCODER3_URL=http://10.0.1.34:8090/stream2
TUNER4_IP=
ENCODER4_URL=
TUNER5_IP=
ENCODER5_URL=
STREAMER_APP=scripts/osprey/directv
CHANNELSIP=10.0.1.65
ALERT_SMTP_SERVER=
ALERT_AUTH_SERVER=
ALERT_EMAIL_FROM=
ALERT_EMAIL_PASS=
ALERT_EMAIL_TO=
UPDATE_SCRIPTS=true
UPDATE_M3US=false
TZ=US/CENTRAL
SPEED_MODE=false
KEEP_WATCHING=4h
HOST_DIR=/volume1/data
Which m3u file is this using? Want to make sure I put my info in the correct file.
Got it figured out. I added dtvospreydeeplinks.m3u to the m3u folder and changed the CDR source to the new m3u file and all is working right now.
Did that first from your earlier post. Added my m3u file but had forgot to change the CDR source url so it sent me to wrong stations. Once I changed that, everything was good. My tuning is now about 8-9 secs versus 11-13 secs with the channel numbers.
My biggest issue was getting the m3u data from Chrome. DTV would lock me out every time I tried to log on thru Chrome and make me reset password. I finally used Chrome to reset (vs my normal browser) and was able to grab the data. One thing that I did notice is that you can use the old password when resetting which I thought odd.
I find it odd that companies feel the need to keep a record of the old password. (my bank keeps last 10)
alot has changed in the ~30yrs of cybersecurity, but the #1 rule has never changed, and they are finally realizing it again. the most secure password is the one you remember.
A post was merged into an existing topic: ADBTuner: A "channel tuning" application for networked Google TV / Android TV devices
I have the C71KW-400 60164.
Is there a way, a trick, using tvquickactions etc to make the channel up/down work within the Favorites collection??
Using the box or the app, this is my main question.
Other thoughts.
DEAL KILLERS for me that make it rarely used:
. Channel up/down toggle ONLY goes thru the ALL collection, or page up/down in the Guide
. Directv stream is one of the most expensive providers but has crap software,
. they have a Channel up/down toggle but it can't do Favs Channel up/down,
. you can't even rearrange your Favorites, its Alpha or Numeric, that's it.
. You can't create your own multiview as in YoutubeTV, at least they offer a group of pre-made multi-views
It seems like you're asking about using this Osprey model without ah4c, or CDVR for that matter? Am I misunderstanding your questions/thoughts? I'm pretty sure everything you're listing as deal killers, are easily handled when this box is used with an encoder, ah4c (or ADBTuner) and CDVR.
You are correct sir, and thanks for the reply.
I'm just trying to figure if there is a way, on this Directv box, do Ch Up/Down for only the Favorites "Collection" since this thread has some Directv box experts perhaps.
I'm on latest created 6/10/26 on Synology NAS- Deeplinks with Osprey's. I haven't seen this issue.
2026.06.29.0212
I would think if cdvr was doing it, it would show up in the support logs.
I think they only allow 2 streams via browser
edit; I just tested, had a stream running in firefox, chrome, and edge. I was thinking of this
so with ch4c it's possible the multiple sandboxed chromes are causing a hickup
Thank you @boukmandutty and @bnhf. Nine months later and I'm finally getting around to setting up AH4C PyATV and a Magewell card "made into" an encoder using GitHub - jpoet/Magewell2TS: Reads audio and video from a Magewell PRO capture card and muxes them into a Transport Stream. · GitHub and GitHub - mackandall/BroadCastHub: Broadcast Hub is a self-hosted web application for managing video capture hardware · GitHub.
Nice explanation here: BroadcastHub For Magewell and Decklink.
The more I think of it, I should be able to run AH4C Apple TV version in a docker container and run everything else to use the Magewell card as an encoder as native. Also, I don't think I need to pass my Intel Quick Sync driver through to the container either then. Am I thinking about this correctly? As long as I'm not using ffmpeg commands within the .env files of AH4C, and instead letting Magewell2TS and BroadCastHub work together to do the encoding, this should work to have just AH4C PyATV in the container?
