It does. It's just not as seamless, or integrated.
@Jean0987654321
Are you seeing any picture quality differences with the FC Android player vs. streaming stick apps?
I realize it’s somewhat subjective with these comparisons but I think the score bugs/bottom banners are “crisper” with the native apps for the ESPN networks.
Not much if any but it does make it easier to pipe in any DRM'd stuff
Sure, but its there...and it works so there's that. I don't need to use ah4c for that and that's key lol. Everything in 1 container lol
I recently got Spectrum and I noticed that they now have an android app. I was wondering, which one of the projects would be best now? I believe there are three that can work now with Spectrum, ah4c, adbtuner and prismcast. I used to use a mix of them with my old setup, but maybe now I can just use one?
I would suggest you start with the FastChannels ah4c bridge. Spectrum is a new addition to this method, but if it's anything like the other providers that are compatible with the bridge, I suspect you'll be very pleased. Spectrum limits concurrent streams to three, as I understand it -- but that'll apply to whatever you do.
Thank you, I will give it a try. I haven't messed with FastChannels yet, so it will be something new.
How's your M3U shaping up? Ready to contribute it?
Absolutely. Do you want me to attach it in here, send it as an issue in GitHub, or something else?
I still haven't figured out about 5 channels that tune fine in the Xfinity streaming guide but don't alter the URL and therefore don't expose the channel ID needed for ah4c. I've tried multiple ID numbers found in the Network tab with the browser console open, but so far none of the numbers I've tried have worked to tune the channels.
Just let me know where you want my mostly complete list.
Thanks.
Here should be fine. Put it in a Preformatted Text block, or use three backticks on the line just before and just after the M3U.
I just want to say THANK YOU for all of the hard work. FastChannels combined with ah4c and PrismCast is all providing a fantastic solution to my needs via Channels DVR. Thanks for all of the hard work that all of you are doing. All is working great for me now that you all have helped me get things operating.
Here it is. As I mentioned earlier, the numbering might seem strange because Xfinity has up to 3 identical HD copies of some channels. I tried to be consistent with the one I picked out of the 200-, 800- or 1400-range, but I might not have gotten them all correct. ah4c couldn't process the dupes, because the tuning command would be something like "tune channel 235 840 1436" which was invalid.
#EXTM3U
#EXTINF:-1 channel-id="141" channel-number="141" tvc-guide-stationid="18715" tvg-group="" tvg-logo="",TR3s
http://{{ .IPADDRESS }}/play/tuner/TR3s-5099759802973064105
#EXTINF:-1 channel-id="142" channel-number="142" tvc-guide-stationid="30419" tvg-group="" tvg-logo="",BETJ
http://{{ .IPADDRESS }}/play/tuner/BETJ-7878962607247849105
#EXTINF:-1 channel-id="250" channel-number="250" tvc-guide-stationid="102828" tvg-group="" tvg-logo="",TF-AT
http://{{ .IPADDRESS }}/play/tuner/TF-AT-8469482692552618105
#EXTINF:-1 channel-id="264" channel-number="264" tvc-guide-stationid="32799" tvg-group="" tvg-logo="",PCHSP
http://{{ .IPADDRESS }}/play/tuner/PCHSP-5060209144122255105
#EXTINF:-1 channel-id="295" channel-number="295" tvc-guide-stationid="17052" tvg-group="" tvg-logo="",AIB
http://{{ .IPADDRESS }}/play/tuner/AIB-5060209144122255105
#EXTINF:-1 channel-id="297" channel-number="297" tvc-guide-stationid="10188" tvg-group="" tvg-logo="",CWBY
http://{{ .IPADDRESS }}/play/tuner/CWBY-6564770433413227105
#EXTINF:-1 channel-id="484" channel-number="484" tvc-guide-stationid="82682" tvg-group="" tvg-logo="",QVC2H
http://{{ .IPADDRESS }}/play/tuner/QVC2H-5446784573060064105
#EXTINF:-1 channel-id="490" channel-number="490" tvc-guide-stationid="102337" tvg-group="" tvg-logo="",QVC3HD
http://{{ .IPADDRESS }}/play/tuner/QVC3HD-5446784573060064105
#EXTINF:-1 channel-id="638" channel-number="638" tvc-guide-stationid="17142" tvg-group="" tvg-logo="",HITN
http://{{ .IPADDRESS }}/play/tuner/HITN-4611886869611784105
#EXTINF:-1 channel-id="668" channel-number="668" tvc-guide-stationid="10222" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s68367_ll_h15_ac.png?w=360&h=270",GALAH
http://{{ .IPADDRESS }}/play/tuner/GALAH-8567499334279041105
#EXTINF:-1 channel-id="677" channel-number="677" tvc-guide-stationid="46384" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/s46384_ll_h9_aa.png?w=360&h=270",TVK
http://{{ .IPADDRESS }}/play/tuner/677
#EXTINF:-1 channel-id="678" channel-number="678" tvc-guide-stationid="47472" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/s47472_ll_h15_ab.png?w=360&h=270",AFRCH
http://{{ .IPADDRESS }}/play/tuner/AFRCH-9206597481012284105
#EXTINF:-1 channel-id="739" channel-number="739" tvc-guide-stationid="70388" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s70388_ll_h15_aa.png?w=360&h=270",OWNHD
http://{{ .IPADDRESS }}/play/tuner/OWNHD-5538810831399914105
#EXTINF:-1 channel-id="741" channel-number="741" tvc-guide-stationid="68065" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s68065_ll_h15_aa.png?w=360&h=270",COOKD
http://{{ .IPADDRESS }}/play/tuner/COOKD-5687967590429447105
#EXTINF:-1 channel-id="742" channel-number="742" tvc-guide-stationid="68827" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s68827_ll_h15_ab.png?w=360&h=270",GMSHW
http://{{ .IPADDRESS }}/play/tuner/GMSHW-6421526418422963105
#EXTINF:-1 channel-id="743" channel-number="743" tvc-guide-stationid="70522" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s70522_ll_h15_ac.png?w=360&h=270",OXYHD
http://{{ .IPADDRESS }}/play/tuner/OXYHD-7830015244833547105
#EXTINF:-1 channel-id="754" channel-number="754" tvc-guide-stationid="58532" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/GNLZZGG003NVX8D.png?w=360&h=270",SMTHD
http://{{ .IPADDRESS }}/play/tuner/SMTHD-7753408411637441105
#EXTINF:-1 channel-id="755" channel-number="755" tvc-guide-stationid="18544" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s67375_ll_h15_ad.png?w=360&h=270",MAGN
http://{{ .IPADDRESS }}/play/tuner/MAGN-5630229262392509105
#EXTINF:-1 channel-id="756" channel-number="756" tvc-guide-stationid="64492" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s64492_ll_h15_aa.png?w=360&h=270",BBCAM
http://{{ .IPADDRESS }}/play/tuner/BBCAM-7159950156799115105
#EXTINF:-1 channel-id="757" channel-number="757" tvc-guide-stationid="67331" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s67331_ll_h15_ab.png?w=360&h=270",WILDH
http://{{ .IPADDRESS }}/play/tuner/WILDH-9049389469014021105
#EXTINF:-1 channel-id="758" channel-number="758" tvc-guide-stationid="46737" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s46737_ll_h15_ab.png?w=360&h=270",OUTHD
http://{{ .IPADDRESS }}/play/tuner/OUTHD-4722987516767773105
#EXTINF:-1 channel-id="792" channel-number="792" tvc-guide-stationid="89714" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s89714_ll_h15_aa.png?w=360&h=270",SECND
http://{{ .IPADDRESS }}/play/tuner/SECND-7065457953075682105
#EXTINF:-1 channel-id="794" channel-number="794" tvc-guide-stationid="66379" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s66379_ll_h9_aa.png?w=360&h=270",FXXHD
http://{{ .IPADDRESS }}/play/tuner/FXXHD-6464688077787938105
#EXTINF:-1 channel-id="797" channel-number="797" tvc-guide-stationid="68433" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s10239_ll_h15_ab.png?w=360&h=270",WKTBD
http://{{ .IPADDRESS }}/play/tuner/WKTBD-8213715354709129105
#EXTINF:-1 channel-id="802" channel-number="802" tvc-guide-stationid="19556" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s51306_ll_h15_ac.png?w=360&h=270",WPCHD
http://{{ .IPADDRESS }}/play/tuner/WPCHD-7775115034909443105
#EXTINF:-1 channel-id="803" channel-number="803" tvc-guide-stationid="11829" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s28708_ll_h15_ac.png?w=360&h=270",WSBHD
http://{{ .IPADDRESS }}/play/tuner/WSBHD-8713109229817176105
#EXTINF:-1 channel-id="804" channel-number="804" tvc-guide-stationid="20430" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s28719_ll_h15_ac.png?w=360&h=270",WAGAD
http://{{ .IPADDRESS }}/play/tuner/WAGAD-8615637520029897105
#EXTINF:-1 channel-id="805" channel-number="805" tvc-guide-stationid="71799" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s71799_ll_h15_ab.png?w=360&h=270",BTVHD
http://{{ .IPADDRESS }}/play/tuner/BTVHD-4888404994044613105
#EXTINF:-1 channel-id="806" channel-number="806" tvc-guide-stationid="19587" tvg-group="Favorites" tvg-logo="https://tmsimg.fancybits.co/assets/s28717_ll_h15_ad.png?w=360&h=270",WXIAD
http://{{ .IPADDRESS }}/play/tuner/WXIAD-7728061817102576105
#EXTINF:-1 channel-id="807" channel-number="807" tvc-guide-stationid="58515" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s58515_ll_h15_ac.png?w=360&h=270",TBSHD
http://{{ .IPADDRESS }}/play/tuner/TBSHD-6937726884423880105
#EXTINF:-1 channel-id="808" channel-number="808" tvc-guide-stationid="59210" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s32356_ll_h15_ac.png?w=360&h=270",GPBDT
http://{{ .IPADDRESS }}/play/tuner/GPBDT-8037961156532819105
#EXTINF:-1 channel-id="809" channel-number="809" tvc-guide-stationid="11479" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/GNLZZGG002BDLYM.png?w=360&h=270",WANF
http://{{ .IPADDRESS }}/play/tuner/WANF-5060209144122255105
#EXTINF:-1 channel-id="810" channel-number="810" tvc-guide-stationid="11959" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s10098_ll_h15_ac.png?w=360&h=270",WUPAH
http://{{ .IPADDRESS }}/play/tuner/WUPAH-5669032547815822105
#EXTINF:-1 channel-id="811" channel-number="811" tvc-guide-stationid="62077" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s62077_ll_h15_ab.png?w=360&h=270",HSNHD
http://{{ .IPADDRESS }}/play/tuner/HSNHD-6267250571981279105
#EXTINF:-1 channel-id="812" channel-number="812" tvc-guide-stationid="30619" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s18633_ll_h15_ad.png?w=360&h=270",WPXAD
http://{{ .IPADDRESS }}/play/tuner/WPXAD-8070479734704376105
#EXTINF:-1 channel-id="814" channel-number="814" tvc-guide-stationid="35286" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s11118_ll_h15_ab.png?w=360&h=270",UNIAT
http://{{ .IPADDRESS }}/play/tuner/UNIAT-6889700984847372105
#EXTINF:-1 channel-id="815" channel-number="815" tvc-guide-stationid="91096" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s91096_ll_h15_af.png?w=360&h=270",NWSND
http://{{ .IPADDRESS }}/play/tuner/NWSND-8231130126327036105
#EXTINF:-1 channel-id="816" channel-number="816" tvc-guide-stationid="45073" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s32356_ll_h15_ac.png?w=360&h=270",WPBAD
http://{{ .IPADDRESS }}/play/tuner/WPBAD-8037961156532819105
#EXTINF:-1 channel-id="817" channel-number="817" tvc-guide-stationid="59296" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s59296_ll_h15_ab.png?w=360&h=270",WEHD
http://{{ .IPADDRESS }}/play/tuner/WE%20HD-6890122293828367105
#EXTINF:-1 channel-id="818" channel-number="818" tvc-guide-stationid="60468" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s60468_ll_h15_aa.png?w=360&h=270",DESTD
http://{{ .IPADDRESS }}/play/tuner/DESTD-5276837144715238105
#EXTINF:-1 channel-id="819" channel-number="819" tvc-guide-stationid="58988" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s58988_ll_h15_aa.png?w=360&h=270",FYIHD
http://{{ .IPADDRESS }}/play/tuner/FYIHD-5354346705419806105
#EXTINF:-1 channel-id="820" channel-number="820" tvc-guide-stationid="60222" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/GNLZZGG0037GZS6.png?w=360&h=270",QVCHD
http://{{ .IPADDRESS }}/play/tuner/QVCHD-5446784573060064105
#EXTINF:-1 channel-id="821" channel-number="821" tvc-guide-stationid="59976" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s59976_ll_h15_aa.png?w=360&h=270",ESWHD
http://{{ .IPADDRESS }}/play/tuner/ESWHD-7642769970651506105
#EXTINF:-1 channel-id="822" channel-number="822" tvc-guide-stationid="59250" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s59250_ll_h15_ac.png?w=360&h=270",CBSSD
http://{{ .IPADDRESS }}/play/tuner/CBSSD-5654718257326569105
#EXTINF:-1 channel-id="825" channel-number="825" tvc-guide-stationid="63236" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s63236_ll_h15_ac.png?w=360&h=270",BETD
http://{{ .IPADDRESS }}/play/tuner/BETD-7878962607247849105
#EXTINF:-1 channel-id="827" channel-number="827" tvc-guide-stationid="66143" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s66143_ll_h15_ac.png?w=360&h=270",UPHD
http://{{ .IPADDRESS }}/play/tuner/UPHD-7858241742464108105
#EXTINF:-1 channel-id="828" channel-number="828" tvc-guide-stationid="61812" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s61812_ll_h15_aa.png?w=360&h=270",E! HD
http://{{ .IPADDRESS }}/play/tuner/E%21 HD-6944445220105035105
#EXTINF:-1 channel-id="830" channel-number="830" tvc-guide-stationid="16300" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/GNLZZGG002H5PTL.png?w=360&h=270",MSNOW
http://{{ .IPADDRESS }}/play/tuner/MSNOW-5064998174375437105
#EXTINF:-1 channel-id="831" channel-number="831" tvc-guide-stationid="58718" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s58718_ll_h15_ac.png?w=360&h=270",FBNHD
http://{{ .IPADDRESS }}/play/tuner/FBNHD-7615660758761926105
#EXTINF:-1 channel-id="832" channel-number="832" tvc-guide-stationid="58812" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s58812_ll_h15_aa.png?w=360&h=270",WEAHD
http://{{ .IPADDRESS }}/play/tuner/WEAHD-7461624676228958105
#EXTINF:-1 channel-id="833" channel-number="833" tvc-guide-stationid="57391" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s57391_ll_h15_ad.png?w=360&h=270",TLCHD
http://{{ .IPADDRESS }}/play/tuner/TLCHD-6615637330030433105
#EXTINF:-1 channel-id="834" channel-number="834" tvc-guide-stationid="58646" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s58646_ll_h15_ac.png?w=360&h=270",CNNHD
http://{{ .IPADDRESS }}/play/tuner/CNNHD-7551018075264600105
#EXTINF:-1 channel-id="835" channel-number="835" tvc-guide-stationid="64549" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s64549_ll_h15_ac.png?w=360&h=270",HLNHD
http://{{ .IPADDRESS }}/play/tuner/HLNHD-8431048223467924105
#EXTINF:-1 channel-id="836" channel-number="836" tvc-guide-stationid="58780" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/GNLZZGG002NF45H.png?w=360&h=270",CNBCD
http://{{ .IPADDRESS }}/play/tuner/CNBCD-6491592537536118105
#EXTINF:-1 channel-id="837" channel-number="837" tvc-guide-stationid="60179" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s60179_ll_h15_ab.png?w=360&h=270",FNCHD
http://{{ .IPADDRESS }}/play/tuner/FNCHD-5714049700463145105
#EXTINF:-1 channel-id="838" channel-number="838" tvc-guide-stationid="51529" tvg-group="Favorites" tvg-logo="https://tmsimg.fancybits.co/assets/s51529_ll_h15_ab.png?w=360&h=270",A&EHD
http://{{ .IPADDRESS }}/play/tuner/A%26EHD-6842223630374944105
#EXTINF:-1 channel-id="839" channel-number="839" tvc-guide-stationid="49438" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s49438_ll_h15_ab.png?w=360&h=270",NGCHD
http://{{ .IPADDRESS }}/play/tuner/NGCHD-5289429020038037105
#EXTINF:-1 channel-id="840" channel-number="840" tvc-guide-stationid="56905" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s56905_ll_h15_ad.png?w=360&h=270",DSCHD
http://{{ .IPADDRESS }}/play/tuner/DSCHD-5021535813287038105
#EXTINF:-1 channel-id="841" channel-number="841" tvc-guide-stationid="42642" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s42642_ll_h15_ac.png?w=360&h=270",TNTHD
http://{{ .IPADDRESS }}/play/tuner/TNTHD-5966517083150279105
#EXTINF:-1 channel-id="842" channel-number="842" tvc-guide-stationid="58452" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s58452_ll_h15_af.png?w=360&h=270",USAHD
http://{{ .IPADDRESS }}/play/tuner/USAHD-6198908101479551105
#EXTINF:-1 channel-id="843" channel-number="843" tvc-guide-stationid="58574" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s58574_ll_h15_aa.png?w=360&h=270",FXHD
http://{{ .IPADDRESS }}/play/tuner/FXHD-7345767321554762105
#EXTINF:-1 channel-id="844" channel-number="844" tvc-guide-stationid="31046" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/GNLZZGG002RMTEH.png?w=360&h=270",MTRND
http://{{ .IPADDRESS }}/play/tuner/MTRND-7937378356785770105
#EXTINF:-1 channel-id="846" channel-number="846" tvc-guide-stationid="32645" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s32645_ll_h15_ab.png?w=360&h=270",ESPND
http://{{ .IPADDRESS }}/play/tuner/ESPND-7642769970651506105
#EXTINF:-1 channel-id="847" channel-number="847" tvc-guide-stationid="45507" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s45507_ll_h15_aa.png?w=360&h=270",ES2HD
http://{{ .IPADDRESS }}/play/tuner/ES2HD-7642769970651506105
#EXTINF:-1 channel-id="849" channel-number="849" tvc-guide-stationid="61854" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/GNLZZGG002RFQBE.png?w=360&h=270",GOLFD
http://{{ .IPADDRESS }}/play/tuner/GOLFD-7547469904399748105
#EXTINF:-1 channel-id="851" channel-number="851" tvc-guide-stationid="60046" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s60046_ll_h15_aa.png?w=360&h=270",VH1HD
http://{{ .IPADDRESS }}/play/tuner/VH1HD-6961539087493247105
#EXTINF:-1 channel-id="852" channel-number="852" tvc-guide-stationid="57708" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s57708_ll_h15_ad.png?w=360&h=270",HISHD
http://{{ .IPADDRESS }}/play/tuner/HISHD-8456573520636503105
#EXTINF:-1 channel-id="853" channel-number="853" tvc-guide-stationid="60964" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s60964_ll_h15_aa.png?w=360&h=270",MTVHD
http://{{ .IPADDRESS }}/play/tuner/MTVHD-7330732356665270105
#EXTINF:-1 channel-id="854" channel-number="854" tvc-guide-stationid="59615" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s59615_ll_h15_ae.png?w=360&h=270",FREE
http://{{ .IPADDRESS }}/play/tuner/FREE-4754737483925103105
#EXTINF:-1 channel-id="855" channel-number="855" tvc-guide-stationid="60150" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s60150_ll_h15_ad.png?w=360&h=270",LIFED
http://{{ .IPADDRESS }}/play/tuner/LIFED-6886139786859842105
#EXTINF:-1 channel-id="856" channel-number="856" tvc-guide-stationid="59337" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s59337_ll_h15_ab.png?w=360&h=270",AMCHD
http://{{ .IPADDRESS }}/play/tuner/AMCHD-8004546766543596105
#EXTINF:-1 channel-id="857" channel-number="857" tvc-guide-stationid="50747" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s50747_ll_h15_ab.png?w=360&h=270",FOODD
http://{{ .IPADDRESS }}/play/tuner/FOODD-8508532143941403105
#EXTINF:-1 channel-id="858" channel-number="858" tvc-guide-stationid="64490" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s64490_ll_h15_ac.png?w=360&h=270",TRTVD
http://{{ .IPADDRESS }}/play/tuner/TRTVD-5197383487287436105
#EXTINF:-1 channel-id="859" channel-number="859" tvc-guide-stationid="49788" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s49788_ll_h15_ab.png?w=360&h=270",HGTVD
http://{{ .IPADDRESS }}/play/tuner/HGTVD-7324914394959750105
#EXTINF:-1 channel-id="860" channel-number="860" tvc-guide-stationid="59303" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s59303_ll_h15_ac.png?w=360&h=270",TRAVD
http://{{ .IPADDRESS }}/play/tuner/TRAVD-7082603579644414105
#EXTINF:-1 channel-id="861" channel-number="861" tvc-guide-stationid="57394" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s57394_ll_h9_ad.png?w=360&h=270",ANPLD
http://{{ .IPADDRESS }}/play/tuner/ANPLD-6959041982342423105
#EXTINF:-1 channel-id="863" channel-number="863" tvc-guide-stationid="59432" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s59432_ll_h15_ac.png?w=360&h=270",NICHD
http://{{ .IPADDRESS }}/play/tuner/NICHD-7294331549102474105
#EXTINF:-1 channel-id="864" channel-number="864" tvc-guide-stationid="59684" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s59684_ll_h15_ae.png?w=360&h=270",DISHD
http://{{ .IPADDRESS }}/play/tuner/DISHD-7281389938284733105
#EXTINF:-1 channel-id="866" channel-number="866" tvc-guide-stationid="60006" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s60006_ll_h15_aa.png?w=360&h=270",DXDHD
http://{{ .IPADDRESS }}/play/tuner/DXDHD-8891398920630634105
#EXTINF:-1 channel-id="868" channel-number="868" tvc-guide-stationid="62420" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s62420_ll_h15_ab.png?w=360&h=270",CMDYD
http://{{ .IPADDRESS }}/play/tuner/CMDYD-6281117796995900105
#EXTINF:-1 channel-id="871" channel-number="871" tvc-guide-stationid="35513" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s61960_ll_h15_ab.png?w=360&h=270",TVONE
http://{{ .IPADDRESS }}/play/tuner/TVONE-8573424887155026105
#EXTINF:-1 channel-id="872" channel-number="872" tvc-guide-stationid="58625" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s58625_ll_h15_ab.png?w=360&h=270",BRVOD
http://{{ .IPADDRESS }}/play/tuner/BRVOD-5861782758316682105
#EXTINF:-1 channel-id="874" channel-number="874" tvc-guide-stationid="58623" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s58623_ll_h15_ae.png?w=360&h=270",SYFYD
http://{{ .IPADDRESS }}/play/tuner/SYFYD-4940667029051783105
#EXTINF:-1 channel-id="875" channel-number="875" tvc-guide-stationid="82547" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s82547_ll_h15_aa.png?w=360&h=270",FS1HD
http://{{ .IPADDRESS }}/play/tuner/FS1HD-5628918118244997105
#EXTINF:-1 channel-id="877" channel-number="877" tvc-guide-stationid="57390" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s57390_ll_h15_ac.png?w=360&h=270",SCIHD
http://{{ .IPADDRESS }}/play/tuner/SCIHD-8701205536934875105
#EXTINF:-1 channel-id="878" channel-number="878" tvc-guide-stationid="59186" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s59186_ll_h15_ac.png?w=360&h=270",PARHD
http://{{ .IPADDRESS }}/play/tuner/PARHD-7314538681861287105
#EXTINF:-1 channel-id="879" channel-number="879" tvc-guide-stationid="45399" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s45399_ll_h15_aa.png?w=360&h=270",NFLHD
http://{{ .IPADDRESS }}/play/tuner/NFLHD-5032472274863868105
#EXTINF:-1 channel-id="892" channel-number="892" tvc-guide-stationid="18822" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s18822_ll_h15_ac.png?w=360&h=270",VICEH
http://{{ .IPADDRESS }}/play/tuner/VICEH-7913625805010596105
#EXTINF:-1 channel-id="893" channel-number="893" tvc-guide-stationid="65342" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s65342_ll_h15_ac.png?w=360&h=270",IDHD
http://{{ .IPADDRESS }}/play/tuner/IDHD-8027895734418552105
#EXTINF:-1 channel-id="897" channel-number="897" tvc-guide-stationid="55887" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s55887_ll_h15_ag.png?w=360&h=270",LMNHD
http://{{ .IPADDRESS }}/play/tuner/LMNHD-7341374787306888105
#EXTINF:-1 channel-id="898" channel-number="898" tvc-guide-stationid="59444" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s59444_ll_h15_ab.png?w=360&h=270",IFCHD
http://{{ .IPADDRESS }}/play/tuner/IFCHD-8822799240044474105
#EXTINF:-1 channel-id="1012" channel-number="1012" tvc-guide-stationid="65556" tvg-group="" tvg-logo="",JTVHD
http://{{ .IPADDRESS }}/play/tuner/JTVHD-6558615370869829105
#EXTINF:-1 channel-id="1032" channel-number="1032" tvc-guide-stationid="63861" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/s70436_ll_h15_ac.png?w=360&h=270",MeTV
http://{{ .IPADDRESS }}/play/tuner/MeTV-4757730922757252105
#EXTINF:-1 channel-id="1036" channel-number="1036" tvc-guide-stationid="31621" tvg-group="" tvg-logo="",WATLD
http://{{ .IPADDRESS }}/play/tuner/WATLD-7275065179929881105
#EXTINF:-1 channel-id="1053" channel-number="1053" tvc-guide-stationid="21593" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/GNLZZGG0028Y563.png?w=360&h=270",WDTA
http://{{ .IPADDRESS }}/play/tuner/WDTA-6057826678156048105
#EXTINF:-1 channel-id="1057" channel-number="1057" tvc-guide-stationid="54426" tvg-group="" tvg-logo="",WATCD
http://{{ .IPADDRESS }}/play/tuner/WATCD-5060209144122255105
#EXTINF:-1 channel-id="1063" channel-number="1063" tvc-guide-stationid="49793" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/GNLZZGG0028Y4QD.png?w=360&h=270",TBNHD
http://{{ .IPADDRESS }}/play/tuner/TBNHD-9025331094502621105
#EXTINF:-1 channel-id="1066" channel-number="1066" tvc-guide-stationid="149611" tvg-group="" tvg-logo="",WHOT
http://{{ .IPADDRESS }}/play/tuner/WHOT-7675479775185161105
#EXTINF:-1 channel-id="1070" channel-number="1070" tvc-guide-stationid="92496" tvg-group="SD" tvg-logo="",LEASE
http://{{ .IPADDRESS }}/play/tuner/LEASE-5207284022909367105
#EXTINF:-1 channel-id="1074" channel-number="1074" tvc-guide-stationid="130282" tvg-group="" tvg-logo="",INTCH
http://{{ .IPADDRESS }}/play/tuner/1074
#EXTINF:-1 channel-id="1079" channel-number="1079" tvc-guide-stationid="203147" tvg-group="" tvg-logo="",FPTN
http://{{ .IPADDRESS }}/play/tuner/1079
#EXTINF:-1 channel-id="1080" channel-number="1080" tvc-guide-stationid="52697" tvg-group="" tvg-logo="",GLC
http://{{ .IPADDRESS }}/play/tuner/GLC-6508225836426605105
#EXTINF:-1 channel-id="1084" channel-number="1084" tvc-guide-stationid="158602" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/s155158_ll_h15_ac.png?w=360&h=270",SHPLC
http://{{ .IPADDRESS }}/play/tuner/SHPLC-5443467767424031105
#EXTINF:-1 channel-id="1089" channel-number="1089" tvc-guide-stationid="73413" tvg-group="" tvg-logo="",FETVH
http://{{ .IPADDRESS }}/play/tuner/FETVH-8447203175556871105
#EXTINF:-1 channel-id="1090" channel-number="1090" tvc-guide-stationid="153694" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/s153694_ll_h15_aa.png?w=360&h=270",INTCH
http://{{ .IPADDRESS }}/play/tuner/1090
#EXTINF:-1 channel-id="1091" channel-number="1091" tvc-guide-stationid="100990" tvg-group="SD" tvg-logo="",WOW
http://{{ .IPADDRESS }}/play/tuner/WOW-5207284022909367105
#EXTINF:-1 channel-id="1092" channel-number="1092" tvc-guide-stationid="102439" tvg-group="SD" tvg-logo="",GOV
http://{{ .IPADDRESS }}/play/tuner/GOV-6617201304304282105
#EXTINF:-1 channel-id="1094" channel-number="1094" tvc-guide-stationid="93925" tvg-group="SD" tvg-logo="",LOCAL
http://{{ .IPADDRESS }}/play/tuner/LOCAL-5207284022909367105
#EXTINF:-1 channel-id="1095" channel-number="1095" tvc-guide-stationid="95461" tvg-group="SD" tvg-logo="",ATL
http://{{ .IPADDRESS }}/play/tuner/ATL-5207284022909367105
#EXTINF:-1 channel-id="1096" channel-number="1096" tvc-guide-stationid="26643" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/GNLZZGG0025V1KJ.png?w=360&h=270",GEMS
http://{{ .IPADDRESS }}/play/tuner/GEMS-5028870578159922105
#EXTINF:-1 channel-id="1097" channel-number="1097" tvc-guide-stationid="67676" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/s67676_ll_h15_aa.png?w=360&h=270",SBN
http://{{ .IPADDRESS }}/play/tuner/SBN-8213919904404227105
#EXTINF:-1 channel-id="1098" channel-number="1098" tvc-guide-stationid="95416" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/s56032_ll_h15_ac.png?w=360&h=270",ATL29
http://{{ .IPADDRESS }}/play/tuner/1098
#EXTINF:-1 channel-id="1099" channel-number="1099" tvc-guide-stationid="109977" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/s109977_ll_h15_aa.png?w=360&h=270",CBN
http://{{ .IPADDRESS }}/play/tuner/CBN-7716237756641876105
#EXTINF:-1 channel-id="1108" channel-number="1108" tvc-guide-stationid="93141" tvg-group="" tvg-logo="",FOXWX
http://{{ .IPADDRESS }}/play/tuner/FOXWX-8615637520029897105
#EXTINF:-1 channel-id="1115" channel-number="1115" tvc-guide-stationid="97163" tvg-group="" tvg-logo="",NEWSM
http://{{ .IPADDRESS }}/play/tuner/NEWSM-6480543351628142105
#EXTINF:-1 channel-id="1117" channel-number="1117" tvc-guide-stationid="89542" tvg-group="" tvg-logo="",BBCNA
http://{{ .IPADDRESS }}/play/tuner/BBCNA-9172023819619664105
#EXTINF:-1 channel-id="1118" channel-number="1118" tvc-guide-stationid="102309" tvg-group="" tvg-logo="",I24ND
http://{{ .IPADDRESS }}/play/tuner/I24ND-8929031781649570105
#EXTINF:-1 channel-id="1128" channel-number="1128" tvc-guide-stationid="68344" tvg-group="" tvg-logo="",CPN1H
http://{{ .IPADDRESS }}/play/tuner/CPN1H-6421427898916050105
#EXTINF:-1 channel-id="1129" channel-number="1129" tvc-guide-stationid="68334" tvg-group="" tvg-logo="",CPN2D
http://{{ .IPADDRESS }}/play/tuner/CPN2D-6421427898916050105
#EXTINF:-1 channel-id="1130" channel-number="1130" tvc-guide-stationid="68332" tvg-group="" tvg-logo="",CPN3H
http://{{ .IPADDRESS }}/play/tuner/CPN3H-6421427898916050105
#EXTINF:-1 channel-id="1151" channel-number="1151" tvc-guide-stationid="61567" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/s56725_ll_h15_ab.png?w=360&h=270",WGTVK
http://{{ .IPADDRESS }}/play/tuner/WGTVK-7960151047544176105
#EXTINF:-1 channel-id="1152" channel-number="1152" tvc-guide-stationid="102035" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/s101364_ll_h15_ac.png?w=360&h=270",GPBKD
http://{{ .IPADDRESS }}/play/tuner/GPBKD-7649588583880442105
#EXTINF:-1 channel-id="1168" channel-number="1168" tvc-guide-stationid="81314" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/s81275_ll_h15_ab.png?w=360&h=270",Movie
http://{{ .IPADDRESS }}/play/tuner/Movie-5761458697067670105
#EXTINF:-1 channel-id="1169" channel-number="1169" tvc-guide-stationid="94962" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/s93430_ll_h15_ab.png?w=360&h=270",Buzzr
http://{{ .IPADDRESS }}/play/tuner/Buzzr-7211854935007329105
#EXTINF:-1 channel-id="1172" channel-number="1172" tvc-guide-stationid="70568" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/s157427_ll_h15_aa.png?w=360&h=270",THIST
http://{{ .IPADDRESS }}/play/tuner/THIST-5872890552651521105
#EXTINF:-1 channel-id="1173" channel-number="1173" tvc-guide-stationid="73155" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/GNLZZGG0028Y4HS.png?w=360&h=270",ANTEN
http://{{ .IPADDRESS }}/play/tuner/ANTEN-6955483015970982105
#EXTINF:-1 channel-id="1177" channel-number="1177" tvc-guide-stationid="95740" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/s90401_ll_h15_ad.png?w=360&h=270",H&I
http://{{ .IPADDRESS }}/play/tuner/H&I-8187881891538519105
#EXTINF:-1 channel-id="1178" channel-number="1178" tvc-guide-stationid="115887" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/s122968_ll_h15_ac.png?w=360&h=270",WGTA5
http://{{ .IPADDRESS }}/play/tuner/WGTA5-5323605593176461105
#EXTINF:-1 channel-id="1180" channel-number="1180" tvc-guide-stationid="91496" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/s91496_ll_h15_ab.png?w=360&h=270",CRIME
http://{{ .IPADDRESS }}/play/tuner/CRIME-6291348777109179105
#EXTINF:-1 channel-id="1181" channel-number="1181" tvc-guide-stationid="107026" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/s147367_ll_h15_aa.png?w=360&h=270",NEST
http://{{ .IPADDRESS }}/play/tuner/1181
#EXTINF:-1 channel-id="1184" channel-number="1184" tvc-guide-stationid="92417" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/s109454_ll_h15_ab.png?w=360&h=270",START
http://{{ .IPADDRESS }}/play/tuner/START-8313187410358697105
#EXTINF:-1 channel-id="1187" channel-number="1187" tvc-guide-stationid="59472" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/s73067_ll_h15_ab.png?w=360&h=270",BOUNC
http://{{ .IPADDRESS }}/play/tuner/BOUNC-5845773528753559105
#EXTINF:-1 channel-id="1188" channel-number="1188" tvc-guide-stationid="92262" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/s112157_ll_h15_ab.png?w=360&h=270",WSB3
http://{{ .IPADDRESS }}/play/tuner/WSB3-5781986371004183105
#EXTINF:-1 channel-id="1194" channel-number="1194" tvc-guide-stationid="113771" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/s111043_ll_h15_aa.png?w=360&h=270",COUR
http://{{ .IPADDRESS }}/play/tuner/COUR-6018868008424352105
#EXTINF:-1 channel-id="1195" channel-number="1195" tvc-guide-stationid="46099" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/GNLZZGG002FEPV8.png?w=360&h=270",GRIT
http://{{ .IPADDRESS }}/play/tuner/GRIT-7174541161516523105
#EXTINF:-1 channel-id="1196" channel-number="1196" tvc-guide-stationid="46098" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/s78851_ll_h15_ab.png?w=360&h=270",COZI
http://{{ .IPADDRESS }}/play/tuner/COZI-8308313939719020105
#EXTINF:-1 channel-id="1209" channel-number="1209" tvc-guide-stationid="33178" tvg-group="" tvg-logo="",FS2
http://{{ .IPADDRESS }}/play/tuner/FS2-8827972050046699105
#EXTINF:-1 channel-id="1211" channel-number="1211" tvc-guide-stationid="114140" tvg-group="Sports" tvg-logo="",NBCSN
http://{{ .IPADDRESS }}/play/tuner/NBCSN-8955280399622974105
#EXTINF:-1 channel-id="1217" channel-number="1217" tvc-guide-stationid="58690" tvg-group="" tvg-logo="",NHLHD
http://{{ .IPADDRESS }}/play/tuner/NHLHD-5825178727236564105
#EXTINF:-1 channel-id="1218" channel-number="1218" tvc-guide-stationid="45526" tvg-group="" tvg-logo="",NBAHD
http://{{ .IPADDRESS }}/play/tuner/NBAHD-7811769821046809105
#EXTINF:-1 channel-id="1219" channel-number="1219" tvc-guide-stationid="62081" tvg-group="" tvg-logo="",MLBHD
http://{{ .IPADDRESS }}/play/tuner/MLBHD-5453095587495952105
#EXTINF:-1 channel-id="1220" channel-number="1220" tvc-guide-stationid="172937" tvg-group="" tvg-logo="",MLS360
http://{{ .IPADDRESS }}/play/tuner/MLS360-5480057999880993105
#EXTINF:-1 channel-id="1224" channel-number="1224" tvc-guide-stationid="60316" tvg-group="" tvg-logo="",TNND
http://{{ .IPADDRESS }}/play/tuner/TNND-5272992504836762105
#EXTINF:-1 channel-id="1228" channel-number="1228" tvc-guide-stationid="111945" tvg-group="" tvg-logo="",ZONAF
http://{{ .IPADDRESS }}/play/tuner/1228
#EXTINF:-1 channel-id="1229" channel-number="1229" tvc-guide-stationid="77033" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s75176_ll_h15_ae.png?w=360&h=270",TUDNH
http://{{ .IPADDRESS }}/play/tuner/TUDNH-8005530728268789105
#EXTINF:-1 channel-id="1230" channel-number="1230" tvc-guide-stationid="72189" tvg-group="" tvg-logo="",FXDED
http://{{ .IPADDRESS }}/play/tuner/FXDED-6796056476188164105
#EXTINF:-1 channel-id="1232" channel-number="1232" tvc-guide-stationid="91588" tvg-group="" tvg-logo="",UNVSH
http://{{ .IPADDRESS }}/play/tuner/UNVSH-7105001527376402105
#EXTINF:-1 channel-id="1237" channel-number="1237" tvc-guide-stationid="66310" tvg-group="" tvg-logo="",SPTMA
http://{{ .IPADDRESS }}/play/tuner/SPTMA-5564587232024669105
#EXTINF:-1 channel-id="1238" channel-number="1238" tvc-guide-stationid="84542" tvg-group="" tvg-logo="",PURST
http://{{ .IPADDRESS }}/play/tuner/PURST-6607957987282037105
#EXTINF:-1 channel-id="1254" channel-number="1254" tvc-guide-stationid="136334" tvg-group="" tvg-logo="",ATLB
http://{{ .IPADDRESS }}/play/tuner/1254
#EXTINF:-1 channel-id="1301" channel-number="1301" tvc-guide-stationid="45654" tvg-group="" tvg-logo="",ESPNU
http://{{ .IPADDRESS }}/play/tuner/ESPNU-5604884968876724105
#EXTINF:-1 channel-id="1325" channel-number="1325" tvc-guide-stationid="111871" tvg-group="HD" tvg-logo="https://tmsimg.fancybits.co/assets/s111871_ll_h15_ac.png?w=360&h=270",ACCHD
http://{{ .IPADDRESS }}/play/tuner/ACCHD-6466348616532783105
#EXTINF:-1 channel-id="1426" channel-number="1426" tvc-guide-stationid="73541" tvg-group="" tvg-logo="",TVLND
http://{{ .IPADDRESS }}/play/tuner/TVLND-8543437118259964105
#EXTINF:-1 channel-id="1427" channel-number="1427" tvc-guide-stationid="68796" tvg-group="" tvg-logo="",POPHD
http://{{ .IPADDRESS }}/play/tuner/POPHD-5956076898283714105
#EXTINF:-1 channel-id="1429" channel-number="1429" tvc-guide-stationid="68385" tvg-group="" tvg-logo="",RLZHD
http://{{ .IPADDRESS }}/play/tuner/RLZHD-4964028528928906105
#EXTINF:-1 channel-id="1431" channel-number="1431" tvc-guide-stationid="82773" tvg-group="" tvg-logo="",INSPD
http://{{ .IPADDRESS }}/play/tuner/INSPD-9185345676986044105
#EXTINF:-1 channel-id="1433" channel-number="1433" tvc-guide-stationid="135626" tvg-group="" tvg-logo="",GETTV
http://{{ .IPADDRESS }}/play/tuner/1433
#EXTINF:-1 channel-id="1437" channel-number="1437" tvc-guide-stationid="82470" tvg-group="" tvg-logo="",CMDTV
http://{{ .IPADDRESS }}/play/tuner/CMDTV-6098489487128677105
#EXTINF:-1 channel-id="1439" channel-number="1439" tvc-guide-stationid="96971" tvg-group="" tvg-logo="",LOGOD
http://{{ .IPADDRESS }}/play/tuner/LOGOD-4800745583381152105
#EXTINF:-1 channel-id="1440" channel-number="1440" tvc-guide-stationid="71280" tvg-group="" tvg-logo="",SUNHD
http://{{ .IPADDRESS }}/play/tuner/SUNHD-5277244023965631105
#EXTINF:-1 channel-id="1446" channel-number="1446" tvc-guide-stationid="78850" tvg-group="" tvg-logo="",JUSTD
http://{{ .IPADDRESS }}/play/tuner/JUSTD-6098489487128677105
#EXTINF:-1 channel-id="1458" channel-number="1458" tvc-guide-stationid="66268" tvg-group="" tvg-logo="",HCHD
http://{{ .IPADDRESS }}/play/tuner/HCHD-7889068523651137105
#EXTINF:-1 channel-id="1459" channel-number="1459" tvc-guide-stationid="61522" tvg-group="" tvg-logo="",HMYS
http://{{ .IPADDRESS }}/play/tuner/HMYS-7889068523651137105
#EXTINF:-1 channel-id="1460" channel-number="1460" tvc-guide-stationid="105723" tvg-group="" tvg-logo="",HFM
http://{{ .IPADDRESS }}/play/tuner/HFM-7889068523651137105
#EXTINF:-1 channel-id="1461" channel-number="1461" tvc-guide-stationid="16062" tvg-group="" tvg-logo="",GFAMH
http://{{ .IPADDRESS }}/play/tuner/GFAMH-6715621136786357105
#EXTINF:-1 channel-id="1462" channel-number="1462" tvc-guide-stationid="69061" tvg-group="" tvg-logo="",OVAHD
http://{{ .IPADDRESS }}/play/tuner/OVAHD-5708379846966999105
#EXTINF:-1 channel-id="1480" channel-number="1480" tvc-guide-stationid="78808" tvg-group="" tvg-logo="",AHCHD
http://{{ .IPADDRESS }}/play/tuner/AHCHD-8573484588337477105
#EXTINF:-1 channel-id="1483" channel-number="1483" tvc-guide-stationid="81289" tvg-group="" tvg-logo="",RECPD
http://{{ .IPADDRESS }}/play/tuner/RECPD-6098489487128677105
#EXTINF:-1 channel-id="1497" channel-number="1497" tvc-guide-stationid="92204" tvg-group="" tvg-logo="",DLCHD
http://{{ .IPADDRESS }}/play/tuner/DLCHD-8063342184085160105
#EXTINF:-1 channel-id="1612" channel-number="1612" tvc-guide-stationid="49141" tvg-group="" tvg-logo="",MTVL
http://{{ .IPADDRESS }}/play/tuner/MTVL-7839360299554010105
#EXTINF:-1 channel-id="1613" channel-number="1613" tvc-guide-stationid="28506" tvg-group="" tvg-logo="",AXSTV
http://{{ .IPADDRESS }}/play/tuner/AXSTV-6895580548351927105
#EXTINF:-1 channel-id="1614" channel-number="1614" tvc-guide-stationid="22561" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/s22561_ll_h15_ad.png?w=360&h=270",MTVCL
http://{{ .IPADDRESS }}/play/tuner/MTVCL-7911074493313088105
#EXTINF:-1 channel-id="1615" channel-number="1615" tvc-guide-stationid="30418" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/s30418_ll_h15_ac.png?w=360&h=270",NICM
http://{{ .IPADDRESS }}/play/tuner/NICM-7294331549102474105
#EXTINF:-1 channel-id="1619" channel-number="1619" tvc-guide-stationid="18717" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/s18717_ll_h15_ab.png?w=360&h=270",CMTM
http://{{ .IPADDRESS }}/play/tuner/CMTM-5510196310798077105
#EXTINF:-1 channel-id="1623" channel-number="1623" tvc-guide-stationid="110222" tvg-group="" tvg-logo="",AFRO
http://{{ .IPADDRESS }}/play/tuner/AFRO-4800690367601384105
#EXTINF:-1 channel-id="1624" channel-number="1624" tvc-guide-stationid="110289" tvg-group="" tvg-logo="",CLEOD
http://{{ .IPADDRESS }}/play/tuner/CLEOD-5158498452642579105
#EXTINF:-1 channel-id="1627" channel-number="1627" tvc-guide-stationid="97409" tvg-group="" tvg-logo="",ASPRE
http://{{ .IPADDRESS }}/play/tuner/ASPRE-6032978207481320105
#EXTINF:-1 channel-id="1628" channel-number="1628" tvc-guide-stationid="14897" tvg-group="" tvg-logo="",BHERH
http://{{ .IPADDRESS }}/play/tuner/BHERH-6493457854932913105
#EXTINF:-1 channel-id="1630" channel-number="1630" tvc-guide-stationid="18718" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/s18718_ll_h15_ad.png?w=360&h=270",BETSO
http://{{ .IPADDRESS }}/play/tuner/BETSO-7878962607247849105
#EXTINF:-1 channel-id="1631" channel-number="1631" tvc-guide-stationid="99918" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/s99918_ll_h15_ab.png?w=360&h=270",BETGS
http://{{ .IPADDRESS }}/play/tuner/BETGS-7878962607247849105
#EXTINF:-1 channel-id="1632" channel-number="1632" tvc-guide-stationid="45928" tvg-group="SD" tvg-logo="",BETHH
http://{{ .IPADDRESS }}/play/tuner/BETHH-7878962607247849105
#EXTINF:-1 channel-id="1636" channel-number="1636" tvc-guide-stationid="126076" tvg-group="" tvg-logo="",GRIO
http://{{ .IPADDRESS }}/play/tuner/1636
#EXTINF:-1 channel-id="1637" channel-number="1637" tvc-guide-stationid="83098" tvg-group="" tvg-logo="",RVLTD
http://{{ .IPADDRESS }}/play/tuner/RVLTD-8807857965719248105
#EXTINF:-1 channel-id="1639" channel-number="1639" tvc-guide-stationid="75077" tvg-group="" tvg-logo="",MTV2D
http://{{ .IPADDRESS }}/play/tuner/MTV2D-8661909423753322105
#EXTINF:-1 channel-id="1668" channel-number="1668" tvc-guide-stationid="10183" tvg-group="" tvg-logo="",EWTNH
http://{{ .IPADDRESS }}/play/tuner/EWTNH-4991563134800892105
#EXTINF:-1 channel-id="1681" channel-number="1681" tvc-guide-stationid="21781" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/GNLZZGG0028Y5CH.png?w=360&h=270",WORD
http://{{ .IPADDRESS }}/play/tuner/WORD-7167931338548082105
#EXTINF:-1 channel-id="1682" channel-number="1682" tvc-guide-stationid="101664" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/s101664_ll_h15_ab.png?w=360&h=270",IMPCT
http://{{ .IPADDRESS }}/play/tuner/IMPCT-6768722622460939105
#EXTINF:-1 channel-id="1684" channel-number="1684" tvc-guide-stationid="80834" tvg-group="" tvg-logo="",JBSHD
http://{{ .IPADDRESS }}/play/tuner/JBSHD-8123426151736990105
#EXTINF:-1 channel-id="1701" channel-number="1701" tvc-guide-stationid="74796" tvg-group="" tvg-logo="",DISJr
http://{{ .IPADDRESS }}/play/tuner/DISJr-7202045367195151105
#EXTINF:-1 channel-id="1702" channel-number="1702" tvc-guide-stationid="82649" tvg-group="" tvg-logo="",NJRHD
http://{{ .IPADDRESS }}/play/tuner/NJRHD-8763340561752910105
#EXTINF:-1 channel-id="1709" channel-number="1709" tvc-guide-stationid="50338" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/s50338_ll_h15_ab.png?w=360&h=270",BABY
http://{{ .IPADDRESS }}/play/tuner/BABY-7198669126145435105
#EXTINF:-1 channel-id="1714" channel-number="1714" tvc-guide-stationid="67749" tvg-group="" tvg-logo="",DFCHD
http://{{ .IPADDRESS }}/play/tuner/DFCHD-9186663754963156105
#EXTINF:-1 channel-id="1721" channel-number="1721" tvc-guide-stationid="126631" tvg-group="" tvg-logo="",PRIMO
http://{{ .IPADDRESS }}/play/tuner/PRIMO-4801348007321041105
#EXTINF:-1 channel-id="1722" channel-number="1722" tvc-guide-stationid="102442" tvg-group="" tvg-logo="",KIDST
http://{{ .IPADDRESS }}/play/tuner/KIDST-5081096154054301105
#EXTINF:-1 channel-id="1727" channel-number="1727" tvc-guide-stationid="82654" tvg-group="" tvg-logo="",NTOON
http://{{ .IPADDRESS }}/play/tuner/NTOON-7294331549102474105
#EXTINF:-1 channel-id="1729" channel-number="1729" tvc-guide-stationid="109727" tvg-group="" tvg-logo="",NICK2
http://{{ .IPADDRESS }}/play/tuner/NICK2-7294331549102474105
#EXTINF:-1 channel-id="1736" channel-number="1736" tvc-guide-stationid="159817" tvg-group="" tvg-logo="",METNS
http://{{ .IPADDRESS }}/play/tuner/METNS-7895878894359290105
#EXTINF:-1 channel-id="1740" channel-number="1740" tvc-guide-stationid="59036" tvg-group="" tvg-logo="",TNCK
http://{{ .IPADDRESS }}/play/tuner/TNCK-6711995747018669105
#EXTINF:-1 channel-id="1766" channel-number="1766" tvc-guide-stationid="70253" tvg-group="" tvg-logo="",FXMHD
http://{{ .IPADDRESS }}/play/tuner/FXMHD-5093964316190418105
#EXTINF:-1 channel-id="1771" channel-number="1771" tvc-guide-stationid="103890" tvg-group="" tvg-logo="",FLIXD
http://{{ .IPADDRESS }}/play/tuner/FLIXD-7850870454063642105
#EXTINF:-1 channel-id="1786" channel-number="1786" tvc-guide-stationid="113001" tvg-group="" tvg-logo="",SCPXH
http://{{ .IPADDRESS }}/play/tuner/SCPXH-8013373201924930105
#EXTINF:-1 channel-id="1787" channel-number="1787" tvc-guide-stationid="113003" tvg-group="" tvg-logo="",SPXAH
http://{{ .IPADDRESS }}/play/tuner/SPXAH-8013373201924930105
#EXTINF:-1 channel-id="1788" channel-number="1788" tvc-guide-stationid="113004" tvg-group="" tvg-logo="",SPXVH
http://{{ .IPADDRESS }}/play/tuner/SPXVH-8013373201924930105
#EXTINF:-1 channel-id="1789" channel-number="1789" tvc-guide-stationid="113002" tvg-group="SD" tvg-logo="https://tmsimg.fancybits.co/assets/s113002_ll_h15_aa.png?w=360&h=270",SPXWS
http://{{ .IPADDRESS }}/play/tuner/SPXWS-8013373201924930105
#EXTINF:-1 channel-id="3131" channel-number="3131" tvc-guide-stationid="142040" tvg-group="" tvg-logo="",CROSS
http://{{ .IPADDRESS }}/play/tuner/CROSS-8120990479147309105
Wow, I tried this, and it worked nicely, first try. I'm impressed
Thanks for the tip
I know right? It's a touch more work than TVE to get going, but after a month of using it, I'd say it's better than TVE ever was. It doesn't work with as many providers, but most of us are flexible as far as that's concerned these days.
Is there really a difference how you defined the Preroll in the Hosting section than what I'm currently using?
On my Osprey ah4c stack, which uses environmental variables and is noted in the new webui as "set by environment" retains the correct value when I delete the env var in Portainer and restart. Cool - this allows me to easily select which variables are set in the webui just by deleting it at the stack level.
I know that I can add or delete tuners in either the stack level or the webui level. Would it be possible to pause a tuner. Currently I’m running a ah4c container for my Osprey’s and one for Fast Channels Bridge. It'd be nice to run just one container and pause tuners and change scripts as needed.
From Docker Compose in Hosting Section:
volumes:
- ${HOST_DIR}/ah4c/scripts:/opt/scripts # pre/stop/bmitune.sh scripts will be stored in this bound host directory under streamer/app
- ${HOST_DIR}/ah4c/m3u:/opt/m3u # m3u files will be stored here and hosted at http://<hostname or ip>:7654/m3u for use in Channels DVR - Custom Channels settings
- ${HOST_DIR}/ah4c/adb:/root/.android # Persistent data directory for adb keys
- ${HOST_DIR}/ah4c/captions:/opt/captions # Closed caption settings, and the speech model, engine and any GPU driver downloaded from the Closed Captions page. Stays empty unless you turn captions on
- ${PREROLL_FILE:-${HOST_DIR}/ah4c/preroll}:/opt/preroll # A video or still image shown to the DVR instead of NULL packets, during a PLAYBACK_DELAY/PLAYBACK_DETECTION hold or a NULL_FRAME_INSERTION stall. Set PREROLL_FILE to a host path, or drop the file into this directory. Anything ffmpeg reads; prepared once at startup, loops until the real stream is ready
From my ah4c stacks:
volumes:
- ${HOST_DIR:-/data}/ah4c/config:/opt/config # Settings saved from the web interface
- ${HOST_DIR:-/data}/ah4c/scripts:/opt/scripts # pre/stop/bmitune.sh scripts will be stored in this bound host directory under streamer/app
- ${HOST_DIR:-/data}/ah4c/m3u:/opt/m3u # m3u files will be stored here and hosted at http://<hostname or ip>:7654/m3u for use in Channels DVR - Custom Channels settings
- ${HOST_DIR:-/data}/ah4c/adb:/root/.android # Persistent data directory for adb keys
- ${HOST_DIR:-/data}/ah4c/captions:/opt/captions # Closed caption settings, and the speech model, engine and any GPU driver downloaded from the Closed Captions page. Stays empty unless you turn captions on
- ${HOST_DIR:-/data}/ah4c/preroll:/opt/preroll # A video or still image shown to the DVR instead of NULL packets, during a PLAYBACK_DELAY/PLAYBACK_DETECTION hold or a NULL_FRAME_INSERTION stall. Set PREROLL_FILE to a host path, or drop the file into this directory. Anything ffmpeg reads; prepared once at startup, loops until the real stream is ready
So you need the bind mount, regardless.
If you have something in the mount already, it will gray out because it wasn't set in the web UI.
That will take precedence.
Anything else like tuners and such, or set by environment variable.
For example, when you set the number of tuners to anything in the environment variables, it immediately stops all tuner editing through the preferences UI because something has to gate it.
In all honesty, I would recommend just choosing one path or the other, either the environment variables or the preferences. I personally think the settings UI is easier. It just writes all to a portable JSON file you can save and copy and never have to touch again.
It's very nice because if you set up a new container or move to a new server, just copy the JSON file and it just reads it.
So that settings.json file stored in the config directory contains all the data showing on the webui. If so, that actually may make my combining "2 containers" into one container by just changing the json file.
Setup:
Ospreys with env variables thru stack
FC with webui (minimal compose).
Convert Osprey stack variables to webui variables. Save a copy of the json file on the NAS. Copy FC settings.json file to config folder replacing the Osprey json file. Restart container and the webui should show with the FC info.
This looks like a quick way to accomplish what I’m trying to do. I want a quick way to bring back the Osprey's in case of a failure in my system.
Yeah, I mean, I'm considering just moving to an Osprey full-time plugged directly into my TV.
Like, in all honesty, the experience of just using an Osprey with the remote that it comes with is fantastic. And not that I'm losing interest, but I'm getting overwhelmed with all the variables and keeping up with everything. I just want to watch TV. Like, I've been trying to get the Fast Channels player to work the way I want, and it just has been an uphill battle to the point where it's just not worth it. And I can just plug in an Osprey and just watch TV and chill.
I would suggest maybe if you're getting like frustrated, giving that a shot. Like the actual devices themselves, just plugged right into a TV set, work super well. And it's just easy enough to go back to like an Apple TV or an Nvidia Shield to watch streaming apps and then leave the Osprey just for cable.
I'm strongly considering just going that route for now. I'm just finding myself overwhelmed and exhausted, messing with things, and it's just a lot, you know. Getting things right and fighting with hardware is becoming a bit of enough.
I'm really happy with FC. We record more than watch live tv so we always skip ads. I haven’t used the Osprey's since I bridged to FC. Will probably power them down this week but it's good to know that I can use the json file to bring back to life if needed.
Yeah, in my situation, I watch a lot of live TV and sit through commercials.
And just that weird national feed just bugs me. So, trying to get that to work properly has been a lot. And I got really close today, but still was having weird issues where I would have the same ad repeat one after another after another for the same company, back to back to back. And I just can't crack that last little bit. And it's just not worth it for me.
Then I realized when I use DirecTV's DVR, it's just like it was when I had YouTube TV before I even used channels. It records absolutely everything, saves it for nine months, and I can just binge watch some old show I forgot about and not use disk space. So, I mean, it's kind of six of one, half a dozen of the other. I can always plug my Ospreys back into my encoders. But then, in the same token, I'm finding the picture quality is better without that second encoding step, and the audio quality is significantly better with my surround sound.
So, I think I kind of made my choice, but I want to run it for maybe a week and then make a final decision on what I'm going to do long term. Also, the main thing that really bothered me the whole time I've used channels as a whole, which is minor but not something to ignore, is the lack of support for Android. $80 a year is not tiny, although it's not huge, but it is a recurring cost. And I think the least we can ask for is equal support for Android. And just supporting tvOS and iOS and leaving Android, which is really a huge platform, as kind of a second class citizen with really, really buggy apps, is really a shame. I bought two Apple TVs just to use channels, and it's just such a waste of money. I hate them.
