I am having issues with PIP on ShieldTV (2017) . Newer shield doesnt have this issue.
I have tried different remotes and uninstalling/deleting cache/data.
You could try changing the video decoder under Settings > Playback > Advanced
I tried all three options with no luck. I think something broke because I believe it worked 3 days ago. Is the older shield model interfering with the app? Do I need to run a logcat somehow?
Reboot?
That animation and the PIP window is controlled by the Android OS
I have tried rebooting several times. Trying turning off fully.
Still having issues. Performing a factory reset since you cant fix anything on your end it seems. Now that I think about it, I think it may have been twilight effecting it.
Looks like the issue was resolved. Twilight was likely the blame.
