Tivo Stream 4k at the moment. Also have a CCwGTV available
820-FoxNews is recording too
Added info:
I was streaming the HD feed when watching football on Fox - transcoder couldn't keep up. Switched to the non-HD feed and problem solved.
If you're watching and it shows anything less than @ 1.00x it means the transcoder can't keep up with the source material it's transcoding. Most likely because the source material is high bitrate.
Only way I know of to improve that is to use a server that can keep up.
Also, have you tested turning off adaptive streaming or using the old transcoder?
Also, have you tested turning off adaptive streaming (YES)
or using the old transcoder (NO)?
