Anyone here successfully using the Channels DVR on Truenas Scale with a HDHomeRun?
I just migrated over from a complicated Channels install using Proxmox + Docker on a old machine connected to an old slow Synology for storage (using NFS) that has been working flawlessly for years. The new install is on a much more powerful box running Truenas Scale and the Truenas Scale Truecharts Channels DVR app.
Now, all recordings stop shortly after starting with errors like "Cancelling stream 10811DF5/1 ch5.1 after no data was received for 6s". It is always 6 seconds. Eventually all four tuners get in use for the same recording and recording stops. The only meaningful difference I can see might have something to do with networking in Docker vs Kubernetes.
The HDHomeRun, the old box, and the new box are all connected to the same switch a few feet apart in a server rack. The old setup still works fine if I power the docker container back up, so it seems unlikely that the issue lies with the tuner.
Edit: here are the logs from the HDHomeRun:
20230221-00:29:30 Tuner: tuner1 http stream ended (remote closed)
20230221-00:29:38 Tuner: tuner1 tuning 5.1 WNEM-HD (8vsb:569MHz-4)
20230221-00:29:38 Tuner: tuner1 streaming http to 10.0.0.8:30813
20230221-00:30:10 Tuner: tuner1 http stream ended (remote closed)
20230221-00:31:09 Tuner: tuner3 http stream ended (remote closed)
20230221-00:34:26 Tuner: tuner2 http stream ended (remote closed)
20230221-00:35:05 Tuner: tuner0 http stream ended (remote closed)
20230221-00:37:57 Tuner: tuner2 tuning 5.1 WNEM-HD (8vsb:569MHz-4)
20230221-00:37:57 Tuner: tuner2 streaming http to 10.0.0.8:23461
20230221-00:38:38 Tuner: tuner3 tuning 5.1 WNEM-HD (8vsb:569MHz-4)
20230221-00:38:38 Tuner: tuner3 streaming http to 10.0.0.8:18534
20230221-00:39:20 Tuner: tuner0 tuning 5.1 WNEM-HD (8vsb:569MHz-4)
20230221-00:39:20 Tuner: tuner0 streaming http to 10.0.0.8:62486
20230221-00:40:02 Tuner: tuner1 tuning 5.1 WNEM-HD (8vsb:569MHz-4)
20230221-00:40:02 Tuner: tuner1 streaming http to 10.0.0.8:35424
20230221-00:40:39 HTTP: rejecting request from 10.0.0.8 - all tuners in use
20230221-00:40:40 HTTP: rejecting request from 10.0.0.8 - all tuners in use
20230221-00:40:42 HTTP: rejecting request from 10.0.0.8 - all tuners in use
