API for forcing guide refresh
I have a weird use case where I want to add custom programme's to my xmltv and they change more than once a day due to live events. Is there a way to force a refresh via a python script? If so, any guidance on how to auth and access the api or method?
If you are using a custom source, you can specify a URL to your XML file and also choose how often to read the XML file for updates.
Wouldn't this do what you are requesting?
Unless I misunderstood the question.
See this:
