Hi All,
First of all, I’m new to the app and found my way here via Maddox from Home Assistant Forum.
I’ve been testing the beta on a Shield and I’ve noticed using when using the API to:
- launch the app from background (specifically the home screen of the Shield)
- change the channel
The app launches and tunes to the correct channel but black screen is displayed with the play/status bar at the bottom, after around 20seconds a message is displayed “HDHomeRun Not Available”.
Using the following command:
curl -X POST http://192.168.1.32:57000/api/play/channel/101
If I use the command after launching the app, everything works perfectly. I haven’t tested this in the non-beta version yet.
