Forgive (likely) stupid question. On the guide display on Apple TV client, there is a lighter purple line under a portion of the displayed current program, on each line. It appears to show how far into the program the current time is - generally for shows that end on the next 1/2 hour, but shows extending into later hours sometimes have that lighter line extend farther, past the current time and beyond. I can't discern it's some proportion of the program length, what is the meaning of that line length for longer programs?
Thanks-
The line represents progress proportionally. So if the line is only halfway across, it’s 50% over.
Nothing should extend past its own airing block. If so please submit a photo of what you’re seeing. But this isn’t anything we’ve seen reported before.
Ah, makes sense. Thanks.
